nka
(Sebastien Plante)
August 22, 2016, 1:24pm
1
Just to let you know, procedure to make OH2 work in FreeBSD is the same as OH1.
Just add this on “start.sh” before “DIRNAME”
JAVA_HOME="/usr/local/openjdk8"; export JAVA_HOME
and I’m still trying to figure the best way to start the server and have access to it without using “screen”
Also how to secure it for external
Stephen_F
(Stephen Froneman)
August 29, 2016, 9:28pm
2
Can you please help to provide all the steps (sequential commands and download sources). I have tried to install OH on FreeNAS without success. The documentation at that time was very scattered and required source code compilation.
If you can provide the NOOB step by step process, then that will be highly appreciated.
mrMuppet
(Vasco Dunker)
January 25, 2017, 7:51am
3
I’m really having problems istalling it on FreeNAS,too. A step by step tutorial would be really cool!
trumee
(trumee)
August 26, 2017, 6:42pm
4
I modified the rc.d script for openhab2 as follows:
#!/bin/sh
# $FreeBSD:$
# PROVIDE: openhab
# REQUIRE: LOGIN
# KEYWORD: shutdown
# Configuration settings for openhab in /etc/rc.conf:
# Mandatory:
# openhab_enable (bool):
# Set to "NO" by default.
# Set it to "YES" to enable openhab
# Optional:
# openhab_user (bool):
# Set to "openhab" by default.
# openhab_http_port (num):
# Default to 8080
# openhab_https_port (num):
# Default to 8443
# openhab_telnet_port (num):
# Default to 5555
# openhab_home (str):
# Default to "/usr/local/openhab"
. /etc/rc.subr
name="openhab2"
rcvar="${name}_enable"
pidfile="/var/run/${name}.pid"
load_rc_config "${name}"
: ${openhab_enable="NO"}
: ${openhab_user="openhab"}
: ${openhab_http_port=8080}
: ${openhab_https_port=8443}
: ${openhab_telnet_port=5555}
: ${openhab_home="/home/openhab/openhab2"}
required_files="${openhab_home}/conf/services/runtime.cfg"
java_command="/usr/local/bin/java
-Dopenhab.home=${openhab_home}
-Dopenhab.conf=${openhab_home}/conf
-Dopenhab.runtime=${openhab_home}/runtime
-Dopenhab.userdata=${openhab_home}/userdata
-Dopenhab.logdir=${openhab_home}/userdata/logs
-Dfelix.cm.dir=${openhab_home}/userdata/config
-Djetty.host=0.0.0.0
-Dorg.ops4j.pax.web.listening.addresses=0.0.0.0
-Dorg.osgi.service.http.port=${openhab_http_port}
-Dorg.osgi.service.http.port.secure=${openhab_https_port}
-Djava.awt.headless=true -XX:+UseG1GC
-Djava.endorsed.dirs=/usr/local/openjdk8/jre/lib/endorsed:/usr/local/openjdk8/lib/endorsed:${openhab_home}/runtime/lib/endorsed
-Djava.ext.dirs=/usr/local/openjdk8/jre/lib/ext:/usr/local/openjdk8/lib/ext:${openhab_home}/runtime/lib/ext
-Dkaraf.instances=${openhab_home}/runtime/instances
-Dkaraf.home=${openhab_home}/runtime
-Dkaraf.base=${openhab_home}/userdata
-Dkaraf.data=${openhab_home}/userdata
-Dkaraf.etc=${openhab_home}/userdata/etc
-Dkaraf.restart.jvm.supported=true
-Djava.io.tmpdir=${openhab_home}/userdata/tmp
-Djava.util.logging.config.file=${openhab_home}/userdata/etc/java.util.logging.properties
-Dkaraf.startLocalConsole=false
-Dkaraf.startRemoteShell=false
-classpath ${openhab_home}/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.0.8.jar:${openhab_home}/runtime/lib/boot/org.apache.karaf.jaas.boot-4.0.8.jar:${openhab_home}/runt
ime/lib/boot/org.apache.karaf.main-4.0.8.jar:${openhab_home}/runtime/lib/boot/org.osgi.core-6.0.0.jar org.apache.karaf.main.Main"
command="/usr/sbin/daemon"
command_args="-p ${pidfile} -u ${openhab_user} -f ${java_command}"
start_precmd="pid_touch"
start_cmd="openhab_start"
stop_cmd="openhab_stop"
status_cmd="openhab_status"
pid_touch() {
touch ${pidfile}
chown ${openhab_user} ${pidfile}
openhab_start() {
cd ${openhab_home}
echo "Starting ${name}..."
exec ${command} ${command_args}
openhab_stop() {
rc_pid=$(openhab_check_pidfile ${pidfile})
if [ -z "${rc_pid}" ]; then
[ -n "${rc_fast}" ] && return 0
echo "${name} not running? (check ${pidfile})."
return 1
fi
echo "Stopping ${name}..."
kill -KILL ${rc_pid} 2> /dev/null && echo "Killed."
rm -f ${pidfile}
sleep 1
openhab_status() {
rc_pid=$(openhab_check_pidfile $pidfile)
if [ -n "${rc_pid}" ]; then
echo "${name} is running as pid ${rc_pid}."
else
echo "${name} is not running."
return 1
fi
openhab_check_pidfile() {
_pidfile=$1
if [ -z "${_pidfile}" ]; then
err 3 'USAGE: openhab_check_pidfile pidfile'
fi
if [ ! -f ${_pidfile} ]; then
debug "pid file (${_pidfile}): not readable."
return
fi
read _pid < ${_pidfile}
if [ -z "${_pid}" ]; then
debug "pid file (${_pidfile}): no pid in file."
return
fi
echo -n ${_pid}
run_rc_command "$1"
