I spent days with forum topics for Openhab2 to work with MQTT.
I tried to install mymosquitto and tsetse broker and finaly removed the tsetse (even it is a nice name for mqtt broker…)
but the OH2 is still trying to start mymosquitto and tsets.
How can a remove the unwanted tsetse brocker ?
As you can see a still have a refused connection. Some ideas the fix that ?
2017-03-17 10:59:38.609 [ERROR] [penhab.io.transport.mqtt.MqttService] - Error starting broker connection
Unable to connect to server (32103) - java.net.ConnectException: Connection refused (Connection refused)
at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:75)[183:org.openhab.io.transport.mqtt:1.9.0]
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:538)[183:org.openhab.io.transport.mqtt:1.9.0]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_112]
Caused by: java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method)[:1.8.0_112]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)[:1.8.0_112]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)[:1.8.0_112]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)[:1.8.0_112]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)[:1.8.0_112]
at java.net.Socket.connect(Socket.java:589)[:1.8.0_112]
at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:66)[183:org.openhab.io.transport.mqtt:1.9.0]
... 2 more
2017-03-17 10:59:38.639 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'tsetse'
2017-03-17 10:59:38.667 [ERROR] [penhab.io.transport.mqtt.MqttService] - Error starting broker connection
... 2 more
2017-03-17 10:59:38.682 [DEBUG] [ng.mqtt.internal.MqttEventBusBinding] - Initializing MQTT Event Bus Binding
2017-03-17 10:59:38.685 [DEBUG] [ng.mqtt.internal.MqttEventBusBinding] - MQTT Event Bus Binding initialization completed.
I Here the bundle list
openhab> bundle:list | grep MQTT
183 | Active | 80 | 1.9.0 | openHAB MQTT Transport Bundle
194 | Active | 80 | 1.9.0 | openHAB MQTT Binding
openhab>
openhab> feature:list | grep MQ
openhab-action-mqtt | 1.9.0 | x | Started | addons-2.0.0 | MQTT Action
openhab-binding-mqtt1 | 1.9.0 | x | Started | addons-2.0.0 | MQTT Binding
openhab-binding-mqttitude1 | 1.9.0 | | Uninstalled | addons-2.0.0 | OwnTracks (formerly MQTTitude) Binding
openhab-persistence-mqtt | 1.9.0 | | Uninstalled | addons-2.0.0 | MQTT Persistence
esh-tp-paho | 0.9.0.b4 | | Uninstalled | distro-2.0.0 | MQTT v3 Client
openhab-transport-mqtt | 2.0.0 | | Uninstalled | distro-2.0.0 | MQTT Transport
openhab>
Addon.cfg
package = expert
# Access Remote Add-on Repository
# Defines whether the remote openHAB add-on repository should be used for browsing and installing add-ons.
# This not only makes latest snapshots of add-ons available, it is also required for the installation of
# any legacy 1.x add-on. (default is true)
#remote = true
# Include legacy 1.x bindings. If set to true, it also allows the installation of 1.x bindings for which there is
# already a 2.x version available (requires remote repo access, see above). (default is false)
#legacy = true
# A comma-separated list of bindings to install (e.g. "sonos,knx,zwave")
#binding =
MQTT.cfg file :
# Define your MQTT broker connections here for use in the MQTT Binding or MQTT
# Persistence bundles. Replace <broker> with an ID you choose.
# URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
#<broker>.url=tcp://<host>:1883
#mymosquitto.url=tcp://192.168.0.153:1883
# Optional. Client id (max 23 chars) to use when connecting to the broker.
# If not provided a default one is generated.
#<broker>.clientId=<clientId>
#mymosquitto.clientId=toto
# Optional. User id to authenticate with the broker.
#<broker>.user=<user>
# Optional. Password to authenticate with the broker.
#<broker>.pwd=<password>
# Optional. Set the quality of service level for sending messages to this broker.
# Possible values are 0 (Deliver at most once),1 (Deliver at least once) or 2
# (Deliver exactly once). Defaults to 0.
#<broker>.qos=<qos>
# Optional. True or false. Defines if the broker should retain the messages sent to
# it. Defaults to false.
#<broker>.retain=<retain>
#mymosquitto.retain=true
