I have OH2 working on my RPi3 and using Eclipse SmartHome Designer. I have the rule below based on the examples provided in the OH2 tutorial for the Astro Binding, but I’m getting an error in Eclipse that says "no viable alternative at Input ‘Channel’.
rule "Sunset"
Channel 'astro:sun:local:set#start' triggered START
Daylight.sendCommand(OFF)
The virtual switch is defined in my items file as well:
I still can’t get “sunset” to turn on my lights. If I use a cron time, the lights will turn on, but they won’t trigger on the rule below.
rule "Lights on at Sunset"
sendCommand(LightStrips_Right, "240,100,100")
sendCommand(LightStrips_Left, "240,100,100")
I verified the lat and long in the Paper UI for “Local Sun” does match my home.
