after upgrade from version 2.2.1 to version 2.2.2 i got this issue.
After a 3/4 days running I got in the logs this kind of warning, tipically 30/35 minutes before crash:
[WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@21dd81f2' takes more than 5000ms.
[WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@33e76645' takes more than 5000ms.
[WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@3aa9609' takes more than 5000ms.
this is only some examples. Passing time, the numeber of this warning became more frequent, then after 30/35 openhab crash and I have some Java exeption:
2017-10-09 17:37:49.652 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
java.lang.OutOfMemoryError: Java heap space
2017-10-09 17:38:18.433 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - Unexpected thread death: org.eclipse.jetty.util.thread.QueuedThreadPool$2@3670562a in qtp1792984541{STARTED,2<=50<=50,i=17,q=1}
2017-10-09 17:37:49.674 [ERROR] [org.quartz.core.JobRunShell ] - Job event-reloader.casaOH threw an unhandled Exception:
2017-10-09 18:31:24.622 [ERROR] [org.quartz.core.ErrorLogger ] - Job (event-reloader.casaOH threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [104:org.eclipse.smarthome.core.scheduler:0.9.0.201709260841]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [104:org.eclipse.smarthome.core.scheduler:0.9.0.201709260841]
Caused by: java.lang.OutOfMemoryError: Java heap space
2017-10-09 18:31:24.627 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
java.lang.OutOfMemoryError: Java heap space: failed reallocation of scalar replaced objects
2017-10-09 18:31:24.628 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - Unexpected thread death: org.eclipse.jetty.util.thread.QueuedThreadPool$2@3670562a in qtp1792984541{STARTED,2<=50<=50,i=0,q=31}
2017-10-09 17:37:49.662 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
2017-10-09 18:31:24.629 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - Unexpected thread death: org.eclipse.jetty.util.thread.QueuedThreadPool$2@3670562a in qtp1792984541{STARTED,2<=50<=50,i=0,q=31}
2017-10-09 18:31:24.621 [WARN ] [eclipse.jetty.servlet.ServletHandler] - Error for /rest/sitemaps/events/subscribe
2017-10-09 17:38:23.722 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@33e76645' takes more than 5000ms.
2017-10-09 18:31:24.650 [INFO ] [me.model.script.Router.Speed.Execute] - Check Speed Execute on Timer. ROUTER_CHECK_ACTIVE=ON
2017-10-09 19:06:56.164 [WARN ] [eclipse.jetty.servlet.ServletHandler] - Error for /rest/sitemaps/events/subscribe
2017-10-09 19:06:56.165 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //192.168.1.80:8080/rest/sitemaps/events/subscribe
2017-10-09 19:06:56.166 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
2017-10-09 19:06:56.166 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - Unexpected thread death: org.eclipse.jetty.util.thread.QueuedThreadPool$2@3670562a in qtp1792984541{STARTED,2<=50<=50,i=0,q=21}
2017-10-09 19:06:56.179 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.OutOfMemoryError: Java heap space
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) [155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:845) [85:org.eclipse.jetty.servlet:9.3.14.v20161028]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [85:org.eclipse.jetty.servlet:9.3.14.v20161028]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.3.14.v20161028]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [85:org.eclipse.jetty.servlet:9.3.14.v20161028]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:320) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273) [76:org.eclipse.jetty.io:9.3.14.v20161028]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95) [76:org.eclipse.jetty.io:9.3.14.v20161028]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [76:org.eclipse.jetty.io:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at java.lang.Thread.run(Thread.java:745) [?:?]
Caused by: org.glassfish.jersey.server.ContainerException: java.lang.OutOfMemoryError: Java heap space
at org.glassfish.jersey.servlet.internal.ResponseWriter.rethrow(ResponseWriter.java:278) ~[?:?]
at org.glassfish.jersey.servlet.internal.ResponseWriter.failure(ResponseWriter.java:260) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509) ~[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334) ~[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) ~[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) ~[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) ~[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) ~[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
... 31 more
2017-10-09 19:07:07.560 [WARN ] [eclipse.jetty.servlet.ServletHandler] - Error for /rest/sitemaps/events/subscribe
2017-10-09 19:06:56.183 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
2017-10-09 19:07:12.714 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - Unexpected thread death: org.eclipse.jetty.util.thread.QueuedThreadPool$2@3670562a in qtp1792984541{STARTED,2<=50<=50,i=6,q=0}
2017-10-09 19:08:51.916 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@48deb62d' takes more than 5000ms.
2017-10-09 19:07:12.714 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //192.168.1.80:8080/rest/sitemaps/events/subscribe
javax.servlet.ServletException: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.OutOfMemoryError: Java heap space
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
Caused by: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.OutOfMemoryError: Java heap space
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:845) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
... 13 more
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334) ~[?:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) ~[?:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
... 13 more
2017-10-09 19:09:08.881 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@33e76645' takes more than 5000ms.
2017-10-09 19:09:39.592 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@3aa9609' takes more than 5000ms.
2017-10-09 19:10:32.522 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@21dd81f2' takes more than 5000ms.
2017-10-09 19:10:32.522 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@33e76645' takes more than 5000ms.
2017-10-09 19:10:37.402 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Exception during event dispatch [org.osgi.service.event.Event [topic=openhab/command/SMS_SEND_SMS] {bridgemarker=true, item=SMS_SEND_SMS, command=n/a} | {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={event.topics=openhab/*, service.pid=org.openhab.souliss, component.name=org.openhab.binding.souliss, component.id=170, service.id=325, service.bundleid=319, service.scope=bundle} | Bundle(org.openhab.binding.souliss_1.11.0.201709280110 [319])]
at org.openhab.binding.souliss.internal.SoulissBinding.receiveCommand(SoulissBinding.java:135) [319:org.openhab.binding.souliss:1.11.0.201709280110]
at org.openhab.core.events.AbstractEventSubscriber.handleEvent(AbstractEventSubscriber.java:45) [206:org.openhab.core.compat1x:2.2.0.201709301515]
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.sendEvent(EventHandlerProxy.java:415) [3:org.apache.karaf.services.eventadmin:4.1.2]
at org.apache.felix.eventadmin.impl.tasks.HandlerTask.run(HandlerTask.java:90) [3:org.apache.karaf.services.eventadmin:4.1.2]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:?]
Please help me to find issue. Many Thanks
Marco
