Every 4-5 days, my OH installation crashes with the following error:
pi@raspberrypi:~/oh$ ./start.sh
Launching the openHAB runtime…
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.0.0
Release Build
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab> #
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x6851d850, pid=5403, tid=0x5d50f460
# JRE version: Java(TM) SE Runtime Environment (8.0_121-b13) (build 1.8.0_121-b13)
# Java VM: Java HotSpot(TM) Client VM (25.121-b13 mixed mode linux-arm )
# Problematic frame:
# C 0x6851d850
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/pi/oh/userdata/hs_err_pid5403.log
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
./runtime/bin/karaf: line 409: 5403 Aborted ${KARAF_EXEC} "${JAVA}" ${JAVA_OPTS} -Djava.endorsed.dirs="${JAVA_ENDORSED_DIRS}" -Djava.ext.dirs="${JAVA_EXT_DIRS}" -Dkaraf.instances="${KARAF_HOME}/instances" -Dkaraf.home="${KARAF_HOME}" -Dkaraf.base="${KARAF_BASE}" -Dkaraf.data="${KARAF_DATA}" -Dkaraf.etc="${KARAF_ETC}" -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir="${KARAF_DATA}/tmp" -Djava.util.logging.config.file="${KARAF_BASE}/etc/java.util.logging.properties" ${KARAF_SYSTEM_OPTS} ${KARAF_OPTS} ${OPTS} -classpath "${CLASSPATH}" ${MAIN} "$@"
Further information can be found here: hs_err_pid5403.log.pdf (78.1 KB) (apologies for PDF format, the system did not allow me to upload .log file).
Is this something related to OH or something wrong with the Raspberry PI I am running this on?
