I’m using OH 2.1 stable and I have couple of rules files. Some rules files, when changed and automatically reloaded generate some errors, but then they are automatically “refreshed” without any errors, and they seem to work ok. This is oh log:
2017-10-17 22:00:56.641 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'mpd.rules', using it anyway:
The field Tmp_mpdRules.radioChannelChanged refers to the missing type Object
The field Tmp_mpdRules.multiroomChanged refers to the missing type Object
2017-10-17 22:00:56.651 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mpd.rules'
2017-10-17 22:01:42.248 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'mpd.rules', using it anyway:
2017-10-17 22:01:42.290 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule 'Mopidy req': null
2017-10-17 22:01:42.495 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'mpd.rules'
and this is mpd.rules:
import org.eclipse.xtext.xbase.lib.Functions
import org.openhab.core.types.Command
val Functions$Function3<GenericItem, GenericItem, GenericItem, Void> uriChanged = [
uri,
multiroom,
radio_channel |
if (uri.state == "rtsp://livingroom-osmc.local:5004/test") {
multiroom.postUpdate(ON)
else {
multiroom.postUpdate(OFF)
if (uri.state == "dirble:station:36549") {
radio_channel.postUpdate("antyradio")
else if (uri.state == "dirble:station:12786") {
radio_channel.postUpdate("eskarock")
else if (uri.state == "dirble:station:12787") {
radio_channel.postUpdate("trojka")
else {
radio_channel.postUpdate("OFF")
val Functions$Function3<Command, GenericItem, GenericItem, Void> multiroomChanged = [
receivedCommand,
uri,
state |
if (receivedCommand == ON) {
uri.sendCommand("rtsp://livingroom-osmc.local:5004/test")
else if (receivedCommand == OFF) {
uri.sendCommand("")
state.sendCommand("stopped")
val Functions$Function3<Command, GenericItem, GenericItem, Void> radioChannelChanged = [
receivedCommand,
uri,
state |
if (receivedCommand == "antyradio") {
uri.sendCommand("dirble:station:36549")
else if (receivedCommand == "eskarock") {
uri.sendCommand("dirble:station:12786")
else if (receivedCommand == "trojka") {
uri.sendCommand("dirble:station:12787")
else {
uri.sendCommand("")
* Livingroom rules
rule "Livingroom stop"
Item mopidy_livingroom_stop received update OFF
mopidy_livingroom_state.sendCommand("stopped")
rule "Livingroom uri"
Item mopidy_livingroom_uri changed
uriChanged.apply(mopidy_livingroom_uri, mopidy_livingroom_multiroom, mopidy_livingroom_radio_channel)
rule "Livingroom radio channel"
Item mopidy_livingroom_radio_channel received command
radioChannelChanged.apply(receivedCommand, mopidy_livingroom_uri, mopidy_livingroom_state)
* Kitchen rules
rule "Kitchen stop"
Item mopidy_kitchen_stop received update OFF
mopidy_kitchen_state.sendCommand("stopped")
rule "Kitchen uri"
Item mopidy_kitchen_uri changed
uriChanged.apply(mopidy_kitchen_uri, mopidy_kitchen_multiroom, mopidy_kitchen_radio_channel)
rule "Kitchen multiroom"
Item mopidy_kitchen_multiroom received command
multiroomChanged.apply(receivedCommand, mopidy_kitchen_uri, mopidy_kitchen_state)
rule "Kitchen radio channel"
Item mopidy_kitchen_radio_channel received command
radioChannelChanged.apply(receivedCommand, mopidy_kitchen_uri, mopidy_kitchen_state)
* Large bathroom rules
rule "Large bathroom stop"
Item mopidy_bathroom1_stop received update OFF
mopidy_bathroom1_state.sendCommand("stopped")
rule "Large bathroom uri"
Item mopidy_bathroom1_uri changed
uriChanged.apply(mopidy_bathroom1_uri, mopidy_bathroom1_multiroom, mopidy_bathroom1_radio_channel)
rule "Large bathroom multiroom"
Item mopidy_bathroom1_multiroom received command
multiroomChanged.apply(receivedCommand, mopidy_bathroom1_uri, mopidy_bathroom1_state)
rule "Large bathroom radio channel"
Item mopidy_bathroom1_radio_channel received command
radioChannelChanged.apply(receivedCommand, mopidy_bathroom1_uri, mopidy_bathroom1_state)
rule "Large bathroom scene"
Item mysensors_bathroom1_scene received command
if (mopidy_bathroom1_state.state != "playing") {
mopidy_bathroom1_radio_channel.sendCommand("antyradio")
mopidy_bathroom1_state.sendCommand("playing")
else {
mopidy_bathroom1_state.sendCommand("paused")
* Small bathroom rules
rule "Small bathroom stop"
Item mopidy_bathroom2_stop received update OFF
mopidy_bathroom2_state.sendCommand("stopped")
rule "Small bathroom uri"
Item mopidy_bathroom2_uri changed
uriChanged.apply(mopidy_bathroom2_uri, mopidy_bathroom2_multiroom, mopidy_bathroom2_radio_channel)
rule "Small bathroom multiroom"
Item mopidy_bathroom2_multiroom received command
multiroomChanged.apply(receivedCommand, mopidy_bathroom2_uri, mopidy_bathroom2_state)
rule "Small bathroom radio channel"
Item mopidy_bathroom2_radio_channel received command
radioChannelChanged.apply(receivedCommand, mopidy_bathroom2_uri, mopidy_bathroom2_state)
* Common rules
rule "Mopidy req"
System started or
Time cron "0 0/30 * * * ?"
mopidy_livingroom_state_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_livingroom_volume_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_livingroom_uri_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_livingroom_current_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_kitchen_state_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_kitchen_volume_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_kitchen_uri_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_kitchen_current_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_bathroom1_state_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_bathroom1_volume_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_bathroom1_uri_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_bathroom1_current_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_bathroom2_state_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_bathroom2_volume_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_bathroom2_uri_req.sendCommand(OFF);
Thread::sleep(100)
mopidy_bathroom2_current_req.sendCommand(OFF);
Is this something wrong with my rules file, or it is normal ?
