No problem, I will test that without resumeafter - I can always re-write to a known state in rules!
Happy to - if there’s any assistance in testing or whatever I can be - happy to do so, think its great and willing to help I’ve included my chaser config - chaser is mapped in items as a standard switch.
Here is a more in depth look at what I’ve found from testing;
DMX fade values reporting in the console take a very long format, not a visible problem in operational terms - eg. Dining_Floor_Lamp changed from 1.5686274509803921350936661838204599916934967041015625 to 52.5490196078431353043924900703132152557373046875
RGB dimmers recieve color values (eg Item ‘Kitchen_Leds_CabsR_Under1’ received command 240,100,100) but do not respond to this data - no further log data generated or viewable on network in sACNview. Rolling back to the bundled version of the binding restores operation, but breaks the chaser function (as previously described)
Chaser runs and stops at the end fine (but does not repeat) - cannot test resumeafter correctly as I cannot control the RGB channels (I see my possible error in understanding of the resumeafter operation!)
//Chasers
//Kitchen RGB Chase Mode
chaser kitchen_rgb_chasemode [dmxid=“68,69,70,71,72,73,74,75,76,80,81,82,83,84,85,86,87,88”, steps=“2000:255,0,0,128,128,0,0,255,0,0,128,128,0,0,255,128,0,128:0|2000:128,128,0,0,255,0,0,128,128,0,0,255,128,0,128,255,0,0:0|2000:0,255,0,0,128,128,0,0,255,128,0,128,255,0,0,128,128,0:0|2000:0,128,128,0,0,255,128,0,128,255,0,0,128,128,0,0,255,0:0|2000:0,0,255,128,0,128,255,0,0,128,128,0,0,255,0,0,128,128:0|2000:128,0,128,255,0,0,128,128,0,0,255,0,0,128,128,0,0,255:0”, resumeafter=true]
Scott
