OH2 exec item works manually but not from rule
So I have an item defined with the exec binding:
String Script_Trotter_Family_Right_Holiday_Lights  <light> (gHolidayIndoorPower, gIndoor) { channel="exec:command:trotter_modlet_switch:input"}
which runs a command on a server to trigger a modlet switch to turn some lights on/off.
I have the item defined in my sitemap, and it works well through BasicUI:
Switch item=Script_Trotter_Family_Right_Holiday_Lights label="Stair Lights"
So, as usual. my next step was to use this item in a rule:
rule "indoorHolidayLightsOn"
Time cron "0 43 04  ? * * *"
 Script_Trotter_Family_Right_Holiday_Lights.sendCommand(ON)
I used to have other items in the rule too, but I removed them to try to figure out what’s going on here. I have enabled debug for the exec binding
One point I discovered while trying this today:
the event log updates in both cases (baseui and rule):
2017-12-09 04:43:00.097 [ItemCommandEvent ] - Item 'Script_Trotter_Family_Right_Holiday_Lights' received command ON
BUT the openhab.log only shows the exec debug when I trigger it from BasicUI…
PS I am using the smarthome designer so I have ruled out typos in my config, etc
Thanks in advance!
Dave
Extraneous or ?
Yes, I actually fixed that before running the test but forgot to update my post. I have corrected it in the above post now
Please tryout .postUpdate(ON) as in my understanding, :input is meant as an state input.
Tried replacing sendCommand(ON) with postUpdate(ON) but it didn’t work.
I don’t see anything in the event log or the exec debug output when the rule triggers.
Have you used a logInfo in order the check wether the rule triggers in the first place?
Good idea. I added some logging to the rule and I see the log statements. The exec command still isn’t working from the rule though.
rule “indoorHolidayLightsOn”
Time cron “0 04 13 ? * * *”
logError(“holidaylight.rules”, “indoorHolidayLightsOn starting”)
Script_Trotter_Family_Right_Holiday_Lights.postUpdate(ON)
logError(“holidaylight.rules”, “indoorHolidayLightsOn complete”)
Submitted PR with the fix for this
Please note that channels have a type in openHAB 2 so its not supposed to be both an channel accepting OnOffTypes and String types. See also a previous PR:
Rather help by testing the rewrite of the exec binding:
