Hi all. Just started up my OH2 and saw following warning
2018-04-05 19:37:43.053 [hingStatusInfoChangedEvent] - 'homematic:bridge:627dd3ff' changed from INITIALIZING to ONLINE
2018-04-05 19:37:43.084 [WARN ] [matic.handler.HomematicBridgeHandler] - Unable to load RSSI values from bridge '627dd3ff'
2018-04-05 19:37:43.085 [ERROR] [matic.handler.HomematicBridgeHandler] - -1 rssiInfo: unknown.method name (sending rssiInfo()
java.io.IOException: -1 rssiInfo: unknown.method name (sending rssiInfo()
at org.openhab.binding.homematic.internal.communicator.parser.RpcResponseParser.parse(RpcResponseParser.java:47) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:78) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:90) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:66) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.loadRssiInfo(RpcClient.java:351) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.loadRssiValues(AbstractHomematicGateway.java:489) ~[?:?]
at org.openhab.binding.homematic.handler.HomematicBridgeHandler.lambda$0(HomematicBridgeHandler.java:82) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Does anyone know what my problem is? Hardware error?
