Launching the openHAB runtime…
FEHLER: Der angegebene Registrierungsschlüssel bzw. Wert wurde nicht gefunden.
Unable to retrieve JAVA_HOME from Registry
JAVA_HOME is not valid: “”
Das Sprungziel - END wurde nicht gefunden.
karaf.bat: JAVA_HOME not set; results may vary
karaf.bat: Unable to retrieve JAVA_HOME from Registry
karaf.bat: JAVA_HOME is not valid:
i manually added the java home “umgebungsvariable” in windows
that takes me here:
start.bat
WARNING: Running Karaf on a Java HotSpot Client VM because server-mode is not available.
Install Java Developer Kit to fix this.
For more details see http://java.sun.com/products/hotspot/whitepaper.html#client
Welcome to openHAB 2.0.0-SNAPSHOT
Hit ‘’ for a list of available commands
and ‘[cmd] --help’ for help on a specific command.
Hit ‘’ or type ‘system:shutdown’ or ‘logout’ to shutdown openHAB.
Is the final plan to do more admin stuff in paper ui in a later version? (sitemaps, manual items, manual channels) ?
Rules ? or integration of habmin2?
Definitely yes! I removed all features that aren’t really integrating well with openHAB, so that users coming from openHAB 1 are not confused and are wondering what these are good for. I want to enable features in the Paper UI, once they are ready for prime time. See also https://www.youtube.com/watch?v=MV2a5qwtmRE.
And yes, HABmin will also be part of a future distro.
