Hello Guys…
Finally i’m there with my setup where i wanna try connecting OH2 to my KNX installation… Currently i already have another system connected to the KNX with a ABB IP/R IP Router. The already running system (SmartHome/SmartVisu) has KNX connection - but i can’t get OH to connect. I’ve tested both ROUTEr and TUNNEL mode, when using tunnel mode i get this error in openhab.log:
2016-08-23 20:29:53.478 [ERROR] [nx.internal.connection.KNXConnection] - Error connecting to KNX bus: timeout connecting to control endpoint /192.168.50.10:3671 2016-08-23 20:29:53.478 [WARN ] [nx.internal.connection.KNXConnection] - Inital connection to KNX bus failed!
But when setting in Router mode i get following:
2016-08-23 20:48:14.481 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, id=265, bundle=170/mvn:org.openhab.binding/org.openhab.binding.knx/1.9.0.b2]: Unexpected problem updating configuration org.openhab.knx tuwien.auto.calimero.exception.KNXIllegalArgumentException: non-valid routing multicast /192.168.50.10 at tuwien.auto.calimero.knxnetip.KNXnetIPRouting.<init>(KNXnetIPRouting.java:121)[170:org.openhab.binding.knx:1.9.0.b2] at tuwien.auto.calimero.knxnetip.KNXnetIPRouting.<init>(KNXnetIPRouting.java:104)[170:org.openhab.binding.knx:1.9.0.b2] at tuwien.auto.calimero.link.KNXNetworkLinkIP.<init>(KNXNetworkLinkIP.java:192)[170:org.openhab.binding.knx:1.9.0.b2] at org.openhab.binding.knx.internal.connection.KNXConnection.connectByIp(KNXConnection.java:285)[170:org.openhab.binding.knx:1.9.0.b2] at org.openhab.binding.knx.internal.connection.KNXConnection.connect(KNXConnection.java:172)[170:org.openhab.binding.knx:1.9.0.b2] at org.openhab.binding.knx.internal.connection.KNXConnection.updated(KNXConnection.java:438)[170:org.openhab.binding.knx:1.9.0.b2] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1444)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1400)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:143)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:110)[7:org.apache.felix.configadmin:1.8.8] at java.lang.Thread.run(Unknown Source)[:1.8.0_101]
Can the ABB router not handle more than one connection at a time?
