Hi.
Running OH2 with MySensors Binding (2.2.0.201710190834) on RPI2 ethernet GW.
One node with static ID, new node on brand new mini pro with dynamic id.
New node gets id 255, which I found elsewhere that its reserved and it basically means that binding/controller did not assigned node id.
When I was upgrading to OH2, I was looking forward for node id auto assign feature which (i though) is mentioned here
Request for an ID is answered (random free number is given)
I found quite some topics in OH and mysensors forums but none stated clearly that OH2 binding should answer for node id. They usually were happy that static assigned node id worked. (for example here)
I would like to know what is the status of this.
Thank you
