I am trying to configure a Fibaro Roller Shutter 2-Item.
I connected it and tried to configure it via Paper UI.
I can Change the Name and associate it to a Group. But I can’t Change Parameters.
I would like to Change no. 14 to “Toggle Switches”. I can Change it, but when I click on save the message “item updated” is coming up and followed by “ERROR: 404 - not found”.
So, when I come back to the configuration-mode there is still “Momentary Switches” at no. 14.
Any Ideas? Right now my Shutters are not working properly, because I have toggle Switches built in The Relay is switching, but it is switching on an off immediately.
Try to configure your things using HABmin. You can install it using Addons -> User Interfaces.
For z-wave devices this is the recommended UI for configuration.
thanks for your support.
It worked with HABmin. I was able to change no. 10.
I also made the calibration via HABmin. It worked as well.
Unfortunately my toggle switch is not working. I can change the switch position but nothing happens. I can just hear a “click-clack” from the Relais. It is powering-on and immediately powering-off.
Via iOS-App it is not working, when I am just tapping once on the App-Switch. When I am tapping a tripple-tap the roller blind is doing what I want.
I found a Solution with trial and error.
I put no. 17 from 10 to 15 and it works.
Here’s the part from the manual:
In Roller Blind Mode or Venetian Blind mode (parameter 10
set to 0, 1, 2) the parameter determines when the Roller Shutter relays are turned off after reaching a limit switch.
In Gate Mode (parameter 10 set to 3 or 4) the parameter determines a time period after which a gate will start closing after a S2 contact has been disconnected. In this mode, time to turn off the Roller Shutter relays after reaching a limit switch is set to 3 seconds and cannot be modified.
Value of 0 means the gate will note close automatically. Available settings: 0 - 255 (0,1-25,5s).
Default setting: 10 (1s). Parameter size: 1 [byte]
