Hi there,
I’ve been trying in vain to migrate my OH1.8 setup to OH2 for sometime now - I’ve tried on and off and have spent in the order of around 100 hours, but have yet to succeed. The main stumbling block has been the RFXCOM binding - I use a number of Mood controllers around the house for lighting, so without it, it’s a deal breaker.
My attempts to run OH2 alongside OH1.8 are documented across a number of posts, so today I started from scratch with an openHabian install.
I managed to get the RFXCOM binding working with a couple of Dimmer modules through the Paper UI, and when I tried a number of mood controllers, they appeared in the inbox… all good
I then tried to configure the setup via text files, but couldn’t get it to work - the problem seemed to be the bridge configuration not wanting to work. It worked briefly then stopped. I made the change to add the symlink rules and it worked again momentarily before refusing to connect with Invalid port
Having decided to abandon text based setup, I reconfigured everything via the PaperUI again, this time using the symlink /dev/USBrfxcom
, however this gave the Connection to RFXCOM transceiver failed: invalid port
error again, returning serial port to /dev/ttyUSB0
and sending commands to the dimmers works again.
However, when trying various mood controllers, these are no longer picked up and don’t appear in the paper UI.
So, the desire to migrate to OH2 is there, I’m seeing lots of new things in OH2 that I want to try, but am constrained by needing the RFXCOM transceiver to work.
[23:01:19] openhabian@openHABianPi:~$ ls -al /dev/*USB*
crw-rw-rw- 1 root dialout 188, 0 May 6 22:56 /dev/ttyUSB0
lrwxrwxrwx 1 root root 7 May 6 22:26 /dev/USBrfxcom -> ttyUSB0
.things (not currently used, but might help someone spot a glaring error):
Bridge rfxcom:bridge:usb0 [ serialPort="/dev/ttyUSB0" ] {
Thing lighting5 Bedroom1_Left_Lamp_Dimmer [deviceId="14732335.4", subType="LightwaveRF,Siemens"]
Thing lighting5 Bedroom1_Right_Lamp_Dimmer [deviceId="14732335.5", subType="LightwaveRF,Siemens"]
Thing lighting5 Bedroom1_Lamp_Dimmer [deviceId="14732335.6", subType="LightwaveRF,Siemens"]
.items:
Dimmer Bed1_Right_Lamp "Right [%d %%]" ["Lighting"] { channel="rfxcom:lighting5:usb0:Bedroom1_Right_Lamp_Dimmer:dimmingLevel" }
Dimmer Bed1_Left_Lamp "Left [%d %%]" ["Lighting"] { channel="rfxcom:lighting5:usb0:Bedroom1_Left_Lamp_Dimmer:dimmingLevel" }
James
