I setup OH2 and did a fresh pairing of my zwave devices via HABmin (I moved recently so it was easier to just repair rather than migrate the OH1 config). All went well with discovery and I am able to control lights, etc.
I am now trying to port my rules over, but I a bit confused as to how to do so because:
- I’ve used Smarthome Designer in the past and see there is a new OH2 version, but with OH2 I don’t see any item files in conf/items (a side effect of auto discovery?). Not sure how the designer would work without that.
- I could just move my OH1 rules files into conf/rules, but I was hoping to validate them as the names surely have changed (see Front_Door_Light in the example below)
- Should I use the experimental next-gen rule engine?
http://docs.openhab.org/configuration/rules-ng.html
Perhaps I’m just missing the obvious here… any help is greatly appreciated!
Dave
My rules are very simple, for now, see below.
But I do intend on writing more complex rules hence the “high level” questions above
rule "nightLightsOn"
// 6:45pm every day
Time cron "0 45 16 1/1 * ? *"
sendCommand(Front_Door_Light, ON)
