Hi all,
I just copied the example from Astro binding V2.0.0 into SmartHome Designer “rules”- tab and it immediatly marks the line with error "no viable alternative at input ‘Channel’, regardless what I put between the ‘then’ … ‘end’ marks.
Its the only rule currently (for testing) . I can also exclude special, invisible chars of copy/paste.
The items of the ASTRO binding do work. Only these rules won’t apply.
The OH2 logs show no problem on deploymemnt of the rules file.
What’s wrong here ?
Thanks for any hint.
Gerry
