I’m using the Samsung TV binding in OH2. I can switch between all HDMI sources except HDMI 1.
Everytime I choose HDMI1, i see this in the event log:
2016-12-17 16:09:39.421 [ItemStateChangedEvent ] - LRTV_Source changed from HDMI3 to HDMI1
2016-12-17 16:09:39.514 [ItemStateChangedEvent ] - LRTV_Source changed from HDMI1 to HDMI3
Basically it never switches because it always goes back to the original source.
I can switch between every other source(antenna, hdmi2/3/4) Only switching to HDMI1 causes an issue.
Any ideas?
Created a single site map entry…same issue.
Then i found something interesting. Apparently the label is HDMI/DVI; I changed the sitemap and it still doesnt work. Also, now the button just says “%label%” instead of “Android”
