Hello @all,
this is my first posting after starting my openHAB home project.
A few days ago, I startet with a clean Raspberry PI 3 installation and setup of openHAB. The first steps went in a proper way, but there are some questions left. Maybe some of you can help me with this items.
I started using Paper UI to install some Bindings like Astro, System, e.g.
But I recognized, that the system didn´t create the .cfg files after putting in my geolocation for example. Is that normal of do I have a righ problem on my linux system?
Creating this files manually is not a problem, but the default config information is missing in this case. So I assume, that there is something wrong.
When doing apt-get update and apt-get upgrade on the linux system, the openhab2 files are replaced every time. After that, my installed bindings are gone away and I have to reinstall them. Seems to be not normal?!?
Thanks very much for help.
Sebastian
