Hi
It is really a grat thing to have a SPK and i’m sure many users will use the OH2 with their Synologies
… I’m struggeling with the current snapshot (2.0.0.008-SNAPSHOT-DSM6) and the place where the configuration files & folders should be places
Default location
«/volume1/@appstore/openhab2/conf/» has been generated with or without having
«/volume1/public/OpenHAB/conf» (as proposed by «http://docs.openhab.org/installation/synology.html#tested-devices» ) or
«/volume1/public/openhab2/configurations» (as proposed by «http://openhab2.wermescher.com/installation-i-c-installation-von-openhab2-auf-synology-nas/».
(R/W access to everyone)
Installation works, bindings, discovering and adding items are working well too.
But I can not “see” where the configuration files are altered and stored
«/volume1/@appstore/openhab2/conf/» and
«/volume1/public/OpenHAB/conf» look the same, what ever I change on the webpage.
When I alter «/volume1/@appstore/openhab2/conf/services/runtime.cfg» or «addons.cfg», it seems to have no effect on the webpage.
Is it an issue that is known and will be fixed in future releases?
Is there a way to query OpenHAB2 where the confirguration ist taken from (or stored to)?
How can i fix with the current snapshot (2.0.0.008-SNAPSHOT-DSM6) - what can I check to get proper results?
May some give hand?
Thank you for your responses and support!
dodo
