I have my configuration up and running, but have a question about dependencies.
The following bundles are not active:
237 │ Resolved │ 80 │ 2.27 │ Dagger
239 │ Resolved │ 80 │ 5.9.0 │ jna
240 │ Resolved │ 80 │ 5.9.0 │ jna-platform
241 │ Resolved │ 80 │ 1.6.2 │ JavaMail API
242 │ Resolved │ 80 │ 4.1.72.Final │ Netty/Buffer
243 │ Resolved │ 80 │ 4.1.72.Final │ Netty/Codec
244 │ Resolved │ 80 │ 4.1.72.Final │ Netty/Codec/HTTP
245 │ Resolved │ 80 │ 4.1.72.Final │ Netty/Codec/Socks
246 │ Resolved │ 80 │ 4.1.72.Final │ Netty/Common
247 │ Resolved │ 80 │ 4.1.72.Final │ Netty/Handler
248 │ Resolved │ 80 │ 4.1.72.Final │ Netty/Handler/Proxy
249 │ Resolved │ 80 │ 4.1.72.Final │ Netty/Resolver
250 │ Resolved │ 80 │ 2.0.46.Final │ Netty/TomcatNative [OpenSSL - Classes]
251 │ Resolved │ 80 │ 4.1.72.Final │ Netty/Transport
252 │ Resolved │ 80 │ 4.1.72.Final │ Netty/Transport/Classes/Epoll
253 │ Resolved │ 80 │ 4.1.72.Final │ Netty/Transport/Native/Unix/Common
254 │ Resolved │ 80 │ 2.2.19 │ rxjava
255 │ Resolved │ 80 │ 1.0.1 │ IO.Socket Engine Client
256 │ Resolved │ 80 │ 1.0.1 │ IO.Socket Socket Client
257 │ Resolved │ 80 │ 20180813.0.0 │ JSON in Java
259 │ Resolved │ 80 │ 3.7.2 │ Apache Commons Net
260 │ Resolved │ 80 │ 1.9.3 │ Apache OpenNLP Tools
261 │ Resolved │ 80 │ 3.8.1.1 │ Apache ServiceMix :: Bundles :: okhttp
262 │ Resolved │ 80 │ 1.13.0.1 │ Apache ServiceMix :: Bundles :: okio
263 │ Resolved │ 80 │ 2.1.2 │ Java Concurrency Tools Core Library
304 │ Resolved │ 80 │ 1.0.3 │ reactive-streams
Not sure what bundles rely on them. As I understand it, those dependencies are activated on demand by other bundles. Is that correct? If so, are they associated in with core bundles or add-ons? If I restart them in karaf, they change to Active, but they do not activate on reboot.
If add-ons, here is my list:
265 │ Active │ 80 │ 3.3.0.202201231119 │ openHAB Add-ons :: Bundles :: Astro Binding
266 │ Active │ 80 │ 3.3.0.202201231127 │ openHAB Add-ons :: Bundles :: Exec Binding
267 │ Active │ 80 │ 3.3.0.202201231137 │ openHAB Add-ons :: Bundles :: Mail Binding
268 │ Active │ 80 │ 3.3.0.202201231139 │ openHAB Add-ons :: Bundles :: MQTT Broker Binding
269 │ Active │ 81 │ 3.3.0.202201231208 │ openHAB Add-ons :: Bundles :: MQTT EspMilightHub
270 │ Active │ 81 │ 3.3.0.202201231208 │ openHAB Add-ons :: Bundles :: MQTT Things and Channels
271 │ Active │ 82 │ 3.3.0.202201231209 │ openHAB Add-ons :: Bundles :: MQTT HomeAssistant Convention
272 │ Active │ 82 │ 3.3.0.202201231209 │ openHAB Add-ons :: Bundles :: MQTT Homie Convention
273 │ Active │ 80 │ 3.3.0.202201231141 │ openHAB Add-ons :: Bundles :: Network Binding
274 │ Active │ 80 │ 3.3.0.202201231142 │ openHAB Add-ons :: Bundles :: NTP Binding
275 │ Active │ 80 │ 3.3.0.202201231144 │ openHAB Add-ons :: Bundles :: OpenWeatherMap Binding
276 │ Active │ 80 │ 3.3.0.202201231146 │ openHAB Add-ons :: Bundles :: Pushover Binding
277 │ Active │ 80 │ 3.3.0.202201231148 │ openHAB Add-ons :: Bundles :: Roku Binding
279 │ Active │ 80 │ 3.3.0.202201231153 │ openHAB Add-ons :: Bundles :: Systeminfo Binding
280 │ Active │ 80 │ 3.3.0.202201220348 │ openHAB Add-ons :: Bundles :: ZWave Binding
291 │ Active │ 80 │ 3.3.0.202201231200 │ openHAB Add-ons :: Bundles :: IO :: openHAB Cloud Connector
292 │ Active │ 80 │ 3.3.0.202201231201 │ openHAB Add-ons :: Bundles :: Persistence Service :: MapDB
293 │ Active │ 80 │ 3.3.0.202201231202 │ openHAB Add-ons :: Bundles :: Persistence Service :: RRD4j
294 │ Active │ 75 │ 3.3.0.202201231202 │ openHAB Add-ons :: Bundles :: Transformation Service :: Exec
295 │ Active │ 75 │ 3.3.0.202201231202 │ openHAB Add-ons :: Bundles :: Transformation Service :: JavaScript
296 │ Active │ 75 │ 3.3.0.202201231202 │ openHAB Add-ons :: Bundles :: Transformation Service :: JSonPath
297 │ Active │ 75 │ 3.3.0.202201231128 │ openHAB Add-ons :: Bundles :: Transformation Service :: Map
298 │ Active │ 75 │ 3.3.0.202201231202 │ openHAB Add-ons :: Bundles :: Transformation Service :: RegEx
311 │ Active │ 80 │ 3.3.0.202201231148 │ openHAB Add-ons :: Bundles :: SamsungTV Binding
314 │ Active │ 80 │ 3.3.0.202201061617 │ openHAB Add-ons :: Bundles :: SamsungTV Binding
Is there a way to determine which bundles have which dependencies and know which ones are shared? (Note there are two SamsungTV bindings. I cannot install one with the other appearing. I tried uninstalling both using karaf then re-installing using the UI, but both came back.)
