Hey,
I’ve just moved from OH2.5 to OH3.4.4 after many years of stable work.
Migration was smoother than I expected, some minor hiccups with rules except one which I can’t get my head around. I read obviously many posts about ‘how to’, apparently many people suffer from it, and probably it’s my brain limitation that I can’t still get this working. Background
I have eBus binding and one of the items is controller which has time/date in it. After some time it gets out of sync, not the place here to explain what exactly I used it for. In OH2.5 I had
item:
import org.joda.datetime.DateTime
var DateTimeType timeVRC = VaillantVRC470Time.state as DateTimeType
var Number diff = Minutes::minutesBetween(new DateTime(timeVRC.zonedDateTime.toInstant().toEpochMilli), now).getMinutes()
if (diff >= 5) {
In OH3 I get error messages that Minutes are unknown (don’t have exact error but I don’t think it’s important here, I think it’s obvious mapping to Java time is needed regardless; if error makes a difference I can collect it). Question
Can someone give me example of how to map/find minutes difference in my case?
Thanks in advance!
I need your help. I’m not able to get this script running. (Rule: application/javascript)
Made a short test version:
//import java.time.Duration
//import org.joda.datetime.DateTime
var now
// just to see, if the script runs
now=500
events.postUpdate("Handy_OffDuration",now)
When I uncomment any of the import lines, the script does not run. Do I have to import/install the libraries first???
You don’t say which version of OH you are running. If OH 3.4 and that rule type you have to use the standard Nashorn JavaScript method to import Java classes:
var Duration = Java.type('java.time.Duration');
Given this is your first post it means you are just getting started. In that case I strongly recommend against using Nashorn JS and instead use the much more up to date JS Scripting add-on. In OH 3.4 the MIME type for that is application/javascript:ECMAScript 2021 (or something like that) and in OH 4 that becomes the default application/javascript and Nashorn becomes application/javascript:ECMAScript 5.1.
If you use the JS Scripting add-on instead, see the reference docs for the add-on which has pretty much everything you need documented.
It is a much better development environment, not the least in that it provides a decade newer version of JavaScript.
