Script execution of rule with UID 'spotify-2' failed: An error occurred during the script execution: index=1, size=1 in spot
I saw there was a change to the way it executes command line, so I managed to fix the array error, but this is a new one
I believe it’s one of the first 2 rules
rule "Spotify run script"
Item spotify_forceupadte received update
var resp = executeCommandLine("/usr/bin/python /etc/openhab2/scripts/spotify.py", 5000)
// logInfo("Spotify", resp)
rule "Spotify Action"
Item spotify_action received update
var resp = executeCommandLine("/usr/bin/python /etc/openhab/scripts/spotify.py", + spotify_action.state.toString, 5000)
rule "spotify live update"
Time cron "0/30 * * * * ?"
if (spotify_current_playing.state == ON && parse(spotify_lastConnectionDateTime.state.toString).plusSeconds(40).isBefore(now)) {
sendCommand(spotify_forceupadte, ON)
rule "spotify update"
Time cron "0 0/30 * * * ?"
logInfo("Spotify", "Chron prelock")
if (parse(spotify_lastConnectionDateTime.state.toString).plusSeconds(45).isBefore(now)) {
This tells you it is complaining about the second rule from file spotify.rules, for a head start in debugging.
This unhelpful but common message tells you it has something to do with “arrays”.
But wait, I don’t have arrays in my rule?
In this context it is usually talking about the ‘array’ of arguments (x,y,z) to some function.
logInfo("test")
for an example will produce that same error, because logInfo() wants at least two parameters.
So here you’ve only one function, executeCommandLine(), and can deduce there is something wrong with its parameters.
// problem is here ^^^
Either use comma or plus, not both. I guess you have to also add a space.
