I tried to make a alarm script, but it throwas an unhandled exception:
2017-01-19 06:35:30.057 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2017-01-19T06:35:30.054+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
logWarn(<XStringLiteralImpl>,<XStringLiteralImpl>)
sendCommand(<XFeatureCallImplCustom>,<XNumberLiteralImpl>)
<null>.timer15 = <XNullLiteralImplCustom>
sendTelegram(<XStringLiteralImpl>,<XStringLiteralImpl>)
} ] threw an unhandled Exception:
java.lang.RuntimeException: The name '<unkown>' cannot be resolved to an item or type.
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:112)[130:org.eclipse.smarthome.model.script:0.9.0.201701140927]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1115)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1045)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:114)[130:org.eclipse.smarthome.model.script:0.9.0.201701140927]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at com.sun.proxy.$Proxy135.apply(Unknown Source)[:]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:38)[130:org.eclipse.smarthome.model.script:0.9.0.201701140927]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202)[105:org.eclipse.smarthome.core.scheduler:0.9.0.201701140927]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573)[105:org.eclipse.smarthome.core.scheduler:0.9.0.201701140927]
i think the relevant part in my rules is this:
//at +15 min
timer15 = createTimer(now.plusMinutes(15), [|
logWarn("Wecker","+15min")
sendCommand(lichtwecker, 50)
timer15 = null
sendTelegram("daniel","Wecker +15min")
The complete .rules file:
[CODE]
import java.util.concurrent.locks.ReentrantLock
import org.eclipse.smarthome.core.library.types.DecimalType
import org.eclipse.smarthome.model.script.actions.Timer
var Timer timer1 = null
var ReentrantLock lock1 = new ReentrantLock()
var Timer timer10 = null
var Timer timer15 = null
var Timer timer20 = null
var Timer timer30 = null
var Timer timer35 = null
/rule "Initialization"
System started
postUpdate(weckerZeitStunde, 8)
postUpdate(weckerZeitMinute, 15)
postUpdate(weckerMontag, ON)
postUpdate(weckerDienstag, ON)
postUpdate(weckerMittwoch, ON)
postUpdate(weckerDonnerstag, ON)
postUpdate(weckerFreitag, ON)
postUpdate(weckerSamstag, OFF)
postUpdate(weckerSonntag, OFF)
end/
rule "Weckzeit"
Item weckerZeitStunde changed or
Item weckerZeitMinute changed
// If the UI to change the Alarm time is clicked several times the code below
// is subject to race conditions. Therefore we make sure that all events
// are processed one after the other.
lock1.lock()
try {
var String msg = “”
// Copy the Alarm-Time from the UI to local variables
//var stunde = weckerZeitStunde.state as DecimalType
//var minute = weckerZeitMinute.state as DecimalType
// Combine the hour and minutes to one string to be displayed in the
// user interface
if (weckerZeitStunde.state < 10) { msg = "0" }
msg = msg + weckerZeitStunde.state.format("%d") + ":"
if (weckerZeitMinute.state < 10) { msg = msg + "0" }
msg = msg + weckerZeitMinute.state.format("%d")
postUpdate(weckerZeitMessage,msg)
// calculate the alarm time [min]
var int weckzeit1
weckzeit1 = (weckerZeitStunde.state as DecimalType).intValue * 60 +
(weckerZeitMinute.state as DecimalType).intValue
weckzeit1 = weckzeit1.intValue
// calculate current time [min]
var int jetzt1
jetzt1 = now.getMinuteOfDay
jetzt1 = jetzt1.intValue
// calculate the difference between the requested alarm time and
// current time (again in minutes)
var int delta1
delta1 = (weckzeit1 - jetzt1)
delta1 = delta1.intValue
// add one day (1440 minutes) if alarm time for today already passed
if (jetzt1 > weckzeit1) { delta1 = delta1 + 1440 }
// check if there is already an alarm timer; cancel it if present
if (timer1 != null) {
timer1.cancel
timer1 = null
// create a new timer using the calculated delta [min]
timer1 = createTimer(now.plusMinutes(delta1)) [|
// This code will be executed if the timer triggers
// check if alarm clock is armed for this weekday
var Number day = now.getDayOfWeek
if (((day == 1) && (weckerMontag.state == ON)) ||
((day == 2) && (weckerDienstag.state == ON)) ||
((day == 3) && (weckerMittwoch.state == ON)) ||
((day == 4) && (weckerDonnerstag.state == ON)) ||
((day == 5) && (weckerFreitag.state == ON)) ||
((day == 6) && (weckerSamstag.state == ON)) ||
((day == 7) && (weckerSonntag.state == ON))) {
// The things to do if the alarm clock is enabled for this day of week:
logWarn("Wecker","Wecker triggered now")
//at 0 min
sendCommand(coffee, ON)
sendTelegram("daniel","Wecker 0min")
//at +10min
timer10 = createTimer(now.plusMinutes(10), [|
logWarn("Wecker","+10min")
sendCommand(lichtwecker, 10)
timer10 = null
sendTelegram("daniel","Wecker +10min")
//at +15 min
timer15 = null
//at +20 min
timer20 = createTimer(now.plusMinutes(20), [|
logWarn("Wecker","20min")
sendCommand(lichtwecker, 100)
timer20 = null
sendTelegram("daniel","Wecker 20min")
//at +30 min
timer30 = createTimer(now.plusMinutes(30), [|
logWarn("Wecker","+30min")
sendCommand(lichtwecker, 0)
timer30 = null
sendTelegram("daniel","Wecker +30min")
//at +35 min
timer35 = createTimer(now.plusMinutes(35), [|
logWarn("Wecker","+35min")
sendCommand(coffee, OFF)
timer35 = null
sendTelegram("daniel","Wecker +35min")
// Re-Arm the timer to trigger again tomorrow (same time)
timer1.reschedule(now.plusHours(24))
// Here the code ends that executes once the timer triggers
} finally {
// release the lock - we are ready to process the next event
lock1.unlock()
[/CODE]
Each timer throwas an exception.
Any ideas?
thanks
Daniel
