hmm, I upgraded the z wave module and my lock is no longer connecting… having a look at the device list site and I can see my lock there… however I noticed that it says “Supports Security No”?
The device is showing up when I press scan… however it shows up even when I haven’t set the device to join the network (enter master code, #, press 4, #, press 1) and as a result, the door doesn’t say “connected” to confirm it connected to the network.
If I try setting the door to search BEFORE I set openhab to scan, they don’t communicate…
a couple of times it has come back with “node9” because it wasn’t able to query manufacturer information, but in all instances the door is unresponsive…
Update:
I got this from the logs:
2017-09-27 22:52:15.498 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 4: setupNetworkKey useSchemeZero=false
2017-09-27 22:52:16.536 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:a7f7ddf9:node4’ to inbox.
2017-09-27 22:52:16.547 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 4: setupNetworkKey useSchemeZero=false
2017-09-27 22:52:21.588 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 4: setupNetworkKey useSchemeZero=true
2017-09-27 22:52:21.595 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 4: Using Scheme0 Network Key for Key Exchange since we are in inclusion mode.
2017-09-27 22:52:32.387 [ERROR] [curityCommandClassWithInitialization] - NODE 4: SECURITY_INCLUSION_FAILED Failed at step SECURITY_SCHEME_GET: 10000ms passed since last request was sent, secure inclusion failed.
2017-09-27 22:52:33.276 [INFO ] [ommandclass.ZWaveVersionCommandClass] - NODE 4: Command Class LOCK has version 0!
I’ve upped the timeout from 30 to 60, however I don’t think this will matter much… too late to test more tonight, will need to do tomorrow evening
@chris - I am going to chime in here along with the oddity that @ae_0017 and @stevenazari have been mentioning with the User Codes.
So I just updated as seen above to using the newer version of the XML where I get the raw channel, and while I was mucking with XML’s, I modified the UserCodes to 20 as I have one of the locks with the 250 codes. So good news is, my codes all showed up - bad news, they had no labels. So I attempted to label them all, then save. To no surprise, I saw a bunch of “pending” bubbles show up. Refresh … refresh … refresh … still showing the Pending bubbles.
I am seeing in the logs (non-debug atm) that it looks like the send is going through and there are some associated logs that look non-eventful. The problem is it looks like it’s going through, but it’s not really.
My assumption is you’ll ask for some debug logs, and if that’s the case I will indeed try to run that at some point over the coming days. At the moment, my bigger concern is getting my rules fixed with the new Alarm Raw channel first. Then I can tackle this as currently the codes still seem to work - just have no labels in the interface. Call it cosmetic for the moment.
I have been using this build successfully on a pc for a long time, but after i moved to a esxi 5.5 vm and installed the binding again and run feature:install… i keep getting:
2017-09-29 15:34:16.980 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.zwave-2.1.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.zwave [9]
Unresolved requirement: Import-Package: com.google.common.collect
at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:392)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1253)[4:org.apache.felix.fileinstall:3.5.6]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1225)[4:org.apache.felix.fileinstall:3.5.6]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:512)[4:org.apache.felix.fileinstall:3.5.6]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:361)[4:org.apache.felix.fileinstall:3.5.6]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:312)[4:org.apache.felix.fileinstall:3.5.6]
when trying to start the binding, if i install the binding from PaperUI it works, and finds the usb passthrough.
I have been reading this thread as it is a similar issue to mine in that I can’t get it to register securely, and so I have had to ensure the lock is disassociated from openHAB with the following process:
Send “Exclude devices” command for openhab to disassociate from software side
Remove Aeotec zwave stick and unpair from door (hold 2 seconds on stick to enter unpairing mode, THEN unpair process on door)
The door then says “completed” and when searching on z-wave binding, I don’t get an insecure result for the door.
I had restarted openhab and found that for some reason version 2.2 had managed to get back on it - I guess it’s from when I did apt update / upgrade… should that really reinstall bindings?? As a result, both new and old bindings were conflicting and 2.2 (old) was presiding over the new. uninstalling and I can now get the door to connect again…
However I am now at the point where I have the on screen “-76” issue again and can’t save in settings, with the log giving:
2017-09-30 19:21:01.455 [ERROR] [st.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at ‘things/zwave:device:48f1902c:node2/config’ for thing ‘zwave:device:48f1902c:node2’: null
2017-09-30 19:21:02.978 [INFO ] [mmandclass.ZWaveDoorLockCommandClass] - NODE 2: Door-Lock config report - timeoutEnabled=true timeoutMinutes=254, timeoutSeconds=30
As a result, I can’t manage the door at all.
I have also noticed when trying to use the “Actions” buttons (Remove / Set as failed / Reinitialise / heal device), I am getting the below error in chrome console:
TypeError: scope.configuration[scope.parameter.name].indexOf is not a function
at b.scope.updateInConfig (controllers.min.js:1)
at fn (eval at compile (angular.min.js:213), :4:551)
at e (angular.min.js:254)
at b.$eval (angular.min.js:133)
at b.$apply (angular.min.js:134)
at HTMLLIElement. (angular.min.js:254)
at HTMLLIElement.dispatch (jquery.min.js:3)
at HTMLLIElement.r.handle (jquery.min.js:3)
(anonymous) @ angular.min.js:107
(anonymous) @ angular.min.js:81
$apply @ angular.min.js:134
(anonymous) @ angular.min.js:254
dispatch @ jquery.min.js:3
r.handle @ jquery.min.js:3
This stops me from using the buttons in that section…
I think i found the cause of it not working, i had openhab2-addons & openhab2-addons-legacy installed from the repo.
When i deleted the 2 packages, it worked again
Yes, I noticed that they kept getting installed despite being stopped and uninstalled…
On a side note, I’m wondering if there is a user friendly way for users to ensure they are scanning from openhab first before scanning on the device (as that is the order it needs to go in, while not stating that is the case)… maybe a friendly message for secure devices?
I’ve put a new version of the binding here. This is a 2.2 version as mentioned a few days ago - this version also has a change to initialisation sequence. There’s now a new step that will check the Z-Wave Plus configuration and set the lifeline association group.
Hopefully this doesn’t cause any issues . If you spot any problems, please let me know and provide a log (I’m sure you all know the routine ).
One point to note is that this lifeline setting will remove any other lifeline settings (if you have the ‘master’ setting selected in the controller). It also uses the multi-channel association which will hopefully solve issues with Qubino devices.
Any issues - just shout . At the moment I’ve also kept the link to the 2.1 version at the top of this thread…
Exception in thread "Thread-421" java.lang.NullPointerException
at org.openhab.binding.zwave.handler.ZWaveThingHandler.startPolling(ZWaveThingHandler.java:409)
at org.openhab.binding.zwave.handler.ZWaveThingHandler.startPolling(ZWaveThingHandler.java:435)
at org.openhab.binding.zwave.handler.ZWaveThingHandler.initialiseNode(ZWaveThingHandler.java:277)
at org.openhab.binding.zwave.handler.ZWaveThingHandler.ZWaveIncomingEvent(ZWaveThingHandler.java:1278)
at org.openhab.binding.zwave.internal.protocol.ZWaveController.notifyEventListeners(ZWaveController.java:549)
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.setCurrentStage(ZWaveNodeInitStageAdvancer.java:1124)
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.access$5(ZWaveNodeInitStageAdvancer.java:1115)
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer$1.run(ZWaveNodeInitStageAdvancer.java:201)
Will give it a whirl now and let you know tomorrow - many thanks for this
With regards to my initial statement, the inclusion mode got me - newbies don’t know that for secure inclusion, openhab needs to be scanning first, THEN the device needs to be activated for search AND in close proximity, personally think a failure for secure devices shouldn’t add the device because it’s a redherring but if it can’t be avoided then that’s just how it is…
I guess a warning for users to say certain z wave devices require a process and aren’t just plug n play as the manufacturer wants you to think.
openhab> log:list
Logger │ Level
ROOT │ WARN
javax.jmdns │ ERROR
org.apache.karaf.jaas.modules.audit │ INFO
org.apache.karaf.shell.support │ OFF
org.eclipse.smarthome │ INFO
org.jupnp │ ERROR
org.openhab │ INFO
org.openhab.binding.zwave │ INFO
smarthome.event │ INFO
smarthome.event.InboxUpdatedEvent │ ERROR
smarthome.event.ItemAddedEvent │ ERROR
smarthome.event.ItemRemovedEvent │ ERROR
smarthome.event.ItemStateEvent │ ERROR
smarthome.event.ThingAddedEvent │ ERROR
smarthome.event.ThingRemovedEvent │ ERROR
smarthome.event.ThingStatusInfoEvent │ ERROR
Openhab log isn’t updating with an error for this for some reason.
The console error gives:
{“error”:{“message”:“HTTP 405 Method Not Allowed”,“http-code”:405,“exception”:{“class”:“javax.ws.rs.NotAllowedException”,“message”:“HTTP 405 Method Not Allowed”,“localized-message”:“HTTP 405 Method Not Allowed”}}}
