I’ve been doing some more checking and it might be related to security, as I’ve tried starting afresh with 2.2, dev - no security option set and dev security all devices set. I’ve been deleting Things, excluding devices, restarting OH2 between each test. I can’t see the scene channel in any cases with the dev version.
No problem. COMMAND_CLASS_SCENE_ACTIVATION is not listed in <nodeInformationFrame>, it is only listed in <endpoints>.
Yes, all of them, and the exported items in VSCode as well. “Scene Number” is listed as a channel in 2.2, and there is no mention of it in the dev binding in Habmin for example. I also see a different number of channels between 2.2 (14 channels) and dev (15 channels) in Habmin as well.
I think I see the issue. There was an update in the database on March 10, and I’m guessing that was the addition of the scene_number channel because it is not in here. It could have been another update though. @mhilbush or @chris might be able to confirm this. You’ll need to wait for the next binding update to come out and hopefully scene_number will turn up.
Found it… there was an update on March 8 to add SCENE_ACTIVATION, which explains why it is not in the current binding. A view of the history in the database would be handy!
The full history of the published database is on Github, but of course that’s not quite what you’re after, and that’s a bit more difficult unfortunately…
I’m doing some restructuring of the database at the moment - once this is done I’ll publish a new dev binding.
I’ve just updated the binding. This has a complete resynchronisation of the database, and some restructuring to put all the devices into folders based on manufacturer. The database now has 713 live entries (and probably another 50 or 60 partially complete devices) so this should make things a bit more usable.
Im getting this after updating to 11th March 2018.
2018-03-12 21:47:52.778 [ERROR] [mmandclass.ZWaveSecurityCommandClass] - NODE 28: Error decapsulating security message
java.security.InvalidKeyException: No installed provider supports this key: (null)
at javax.crypto.Cipher.chooseProvider(Cipher.java:893) [?:?]
at javax.crypto.Cipher.init(Cipher.java:1249) [?:?]
at javax.crypto.Cipher.init(Cipher.java:1186) [?:?]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveSecurityCommandClass.generateMAC(ZWaveSecurityCommandClass.java:501) [223:org.openhab.binding.zwave:2.3.0.201803111809]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveSecurityCommandClass.getSecurityMessageDecapsulation(ZWaveSecurityCommandClass.java:303) [223:org.openhab.binding.zwave:2.3.0.201803111809]
at org.openhab.binding.zwave.internal.protocol.ZWaveNode.processCommand(ZWaveNode.java:1170) [223:org.openhab.binding.zwave:2.3.0.201803111809]
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$ZWaveReceiveThread.run(ZWaveTransactionManager.java:440) [223:org.openhab.binding.zwave:2.3.0.201803111809]
Its a PSP05 Motion Sensor
Other secure devices seem to work just fine
When I try to include a Fibaro FGS-223 it throws an exception in the log
2018-03-13 08:51:40.462 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 9: setupNetworkKey useSchemeZero=false
2018-03-13 08:51:40.544 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:controller:node9' to inbox.
2018-03-13 08:51:53.744 [ERROR] [ve.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
java.lang.ArrayIndexOutOfBoundsException: 3
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveSecurityCommandClass.isSecurityNonceReportMessage(ZWaveSecurityCommandClass.java:1067) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at org.openhab.binding.zwave.internal.protocol.SerialMessage$SerialMessageComparator.compare(SerialMessage.java:692) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at org.openhab.binding.zwave.internal.protocol.SerialMessage$SerialMessageComparator.compare(SerialMessage.java:1) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at java.util.concurrent.PriorityBlockingQueue.siftUpUsingComparator(Unknown Source) [?:?]
at java.util.concurrent.PriorityBlockingQueue.offer(Unknown Source) [?:?]
at java.util.concurrent.PriorityBlockingQueue.add(Unknown Source) [?:?]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.enqueue(ZWaveController.java:546) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.sendMessage(ZWaveNodeInitStageAdvancer.java:260) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.addToQueue(ZWaveNodeInitStageAdvancer.java:1170) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.advanceNodeStage(ZWaveNodeInitStageAdvancer.java:1082) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.handleNodeQueue(ZWaveNodeInitStageAdvancer.java:230) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.ZWaveIncomingEvent(ZWaveNodeInitStageAdvancer.java:1306) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.notifyEventListeners(ZWaveController.java:567) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:250) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:214) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$7(ZWaveController.java:208) [211:org.openhab.binding.zwave:2.3.0.201803101457]
at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1324) [211:org.openhab.binding.zwave:2.3.0.201803101457]
This is normally caused by a corrupt frame received from the device - or at least a frame that is not what the binding expects. Possibly it’s an invalid Nonce, but that’s just a guess and I’d need to see a debug log showing the received frame to say more.
Those with kwikset door locks: Does anyone have the current status (locked vs unlocked) reporting reliably in OH? I find mine is typically incorrect, even when soley using OH to lock/unlock (that is, no one has manually changed it’s state).
Hey!!
NOOB here looking for some help. I have tried everything I have found in the 2590 post before me to get a Schlage BE469WK setup but for the life of me i keep getting “NODE 9: SECURITY_INC State=FAILED, Reason=GET_SCHEME”
I have done the following
Inclusion = High Power Inclusion
Security inclusion mode = all devices
Network Key = is set
I have reset the Lock and reinstalled openhab
Unless you have a reason for this, go with NWI. Shouldn’t affect the lock though.
Unless you have a reason for this, go with Entry Control Devices. This won’t affect the lock either.
It looks as though you’re not logging the zwave binding in debug mode, which might help in troubleshooting. Have you been excluding the lock between attempts? Are you running inclusion through OH, with the lock close to the controller?
