Here are several examples of a dimmer being set to a level, but the command polling comes back with the previous value of the light. This is with the command polling set to 15s. What makes this even odder, is that it does not happen for all devices of the same type, and it does not always happen for the same device. Adjusting the command polling interval did not have any affect. Other people have previously reported something similar.
Previous values reported by poll (filtered)
2018-08-21 16:00:41.654 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Command received zwave:device:07cb40a2:node30:switch_dimmer --> 21
2018-08-21 16:00:41.654 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 30: Creating new message for command SWITCH_MULTILEVEL_SET
2018-08-21 16:00:41.654 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
2018-08-21 16:00:41.655 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2018-08-21 16:00:41.655 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Adding to device queue
2018-08-21 16:00:41.657 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 30: Sending REQUEST Message = 01 0A 00 13 1E 03 26 01 15 25 85 69
2018-08-21 16:00:41.662 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling intialised at 1800 seconds - start in 15000 milliseconds.
2018-08-21 16:00:41.668 [DEBUG] [org.openhab.binding.zwave.internal.protocol.serialmessage.SendDataMessageClass] - NODE 30: sentData successfully placed on stack.
2018-08-21 16:00:41.668 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 26788: Transaction not completed
2018-08-21 16:00:41.686 [DEBUG] [org.openhab.binding.zwave.internal.protocol.serialmessage.SendDataMessageClass] - NODE 30: SendData Request. CallBack ID = 133, Status = Transmission complete and ACK received(0)
2018-08-21 16:00:41.686 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
2018-08-21 16:00:41.686 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Response processed after 25ms
2018-08-21 16:00:41.686 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 26788: Transaction completed
2018-08-21 16:00:41.686 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: notifyTransactionResponse TID:26788 DONE
2018-08-21 16:00:41.687 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-08-21 16:00:56.662 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling...
2018-08-21 16:00:56.662 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling zwave:device:07cb40a2:node30:switch_dimmer
2018-08-21 16:00:56.662 [DEBUG] [org.openhab.binding.zwave.internal.converter.ZWaveMultiLevelSwitchConverter] - NODE 30: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2018-08-21 16:00:56.662 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 30: Creating new message for command SWITCH_MULTILEVEL_GET
2018-08-21 16:00:56.663 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
2018-08-21 16:00:56.663 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2018-08-21 16:00:56.663 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling zwave:device:07cb40a2:node30:scene_number
2018-08-21 16:00:56.663 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling skipped for zwave:device:07cb40a2:node30:scene_number on COMMAND_CLASS_BASIC
2018-08-21 16:00:56.663 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Adding to device queue
2018-08-21 16:00:56.663 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 30: Sending REQUEST Message = 01 09 00 13 1E 02 26 02 25 86 7E
2018-08-21 16:00:56.674 [DEBUG] [org.openhab.binding.zwave.internal.protocol.serialmessage.SendDataMessageClass] - NODE 30: sentData successfully placed on stack.
2018-08-21 16:00:56.674 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 26792: Transaction not completed
2018-08-21 16:00:56.693 [DEBUG] [org.openhab.binding.zwave.internal.protocol.serialmessage.SendDataMessageClass] - NODE 30: SendData Request. CallBack ID = 134, Status = Transmission complete and ACK received(0)
2018-08-21 16:00:56.693 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
2018-08-21 16:00:56.693 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 26792: Transaction not completed
2018-08-21 16:00:56.701 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Application Command Request (ALIVE:DONE)
2018-08-21 16:00:56.701 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
2018-08-21 16:00:56.701 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2018-08-21 16:00:56.701 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
2018-08-21 16:00:56.701 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveCommandClass] - NODE 30: Received COMMAND_CLASS_SWITCH_MULTILEVEL V1 SWITCH_MULTILEVEL_REPORT
2018-08-21 16:00:56.701 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 30: Switch Multi Level report, value = 0
2018-08-21 16:00:56.701 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-08-21 16:00:56.701 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 0
2018-08-21 16:00:56.701 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Updating channel state zwave:device:07cb40a2:node30:switch_dimmer to 0 [PercentType]
2018-08-21 16:00:56.702 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Commands processed 1.
2018-08-21 16:00:56.702 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5a9fc4aa.
2018-08-21 16:00:56.703 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5a9fc4aa.
2018-08-21 16:00:56.708 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: notifyTransactionResponse TID:26792 DONE
2018-08-21 16:00:56.710 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-08-21 16:01:46.029 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Command received zwave:device:07cb40a2:node30:switch_dimmer --> 58
2018-08-21 16:01:46.030 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 30: Creating new message for command SWITCH_MULTILEVEL_SET
2018-08-21 16:01:46.031 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
2018-08-21 16:01:46.031 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2018-08-21 16:01:46.032 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Adding to device queue
2018-08-21 16:01:46.033 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 30: Sending REQUEST Message = 01 0A 00 13 1E 03 26 01 3A 25 88 4B
2018-08-21 16:01:46.043 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling intialised at 1800 seconds - start in 15000 milliseconds.
2018-08-21 16:01:46.047 [DEBUG] [org.openhab.binding.zwave.internal.protocol.serialmessage.SendDataMessageClass] - NODE 30: sentData successfully placed on stack.
2018-08-21 16:01:46.047 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 26795: Transaction not completed
2018-08-21 16:01:46.060 [DEBUG] [org.openhab.binding.zwave.internal.protocol.serialmessage.SendDataMessageClass] - NODE 30: SendData Request. CallBack ID = 136, Status = Transmission complete and ACK received(0)
2018-08-21 16:01:46.060 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
2018-08-21 16:01:46.060 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Response processed after 18ms
2018-08-21 16:01:46.060 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 26795: Transaction completed
2018-08-21 16:01:46.060 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: notifyTransactionResponse TID:26795 DONE
2018-08-21 16:01:46.061 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-08-21 16:02:01.043 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling...
2018-08-21 16:02:01.043 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling zwave:device:07cb40a2:node30:switch_dimmer
2018-08-21 16:02:01.043 [DEBUG] [org.openhab.binding.zwave.internal.converter.ZWaveMultiLevelSwitchConverter] - NODE 30: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2018-08-21 16:02:01.043 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 30: Creating new message for command SWITCH_MULTILEVEL_GET
2018-08-21 16:02:01.043 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
2018-08-21 16:02:01.043 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2018-08-21 16:02:01.043 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling zwave:device:07cb40a2:node30:scene_number
2018-08-21 16:02:01.043 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling skipped for zwave:device:07cb40a2:node30:scene_number on COMMAND_CLASS_BASIC
2018-08-21 16:02:01.043 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Adding to device queue
2018-08-21 16:02:01.044 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 30: Sending REQUEST Message = 01 09 00 13 1E 02 26 02 25 89 71
2018-08-21 16:02:01.059 [DEBUG] [org.openhab.binding.zwave.internal.protocol.serialmessage.SendDataMessageClass] - NODE 30: sentData successfully placed on stack.
2018-08-21 16:02:01.059 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 26796: Transaction not completed
2018-08-21 16:02:01.072 [DEBUG] [org.openhab.binding.zwave.internal.protocol.serialmessage.SendDataMessageClass] - NODE 30: SendData Request. CallBack ID = 137, Status = Transmission complete and ACK received(0)
2018-08-21 16:02:01.072 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
2018-08-21 16:02:01.072 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 26796: Transaction not completed
2018-08-21 16:02:01.080 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Application Command Request (ALIVE:DONE)
2018-08-21 16:02:01.080 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
2018-08-21 16:02:01.080 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2018-08-21 16:02:01.080 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
2018-08-21 16:02:01.081 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveCommandClass] - NODE 30: Received COMMAND_CLASS_SWITCH_MULTILEVEL V1 SWITCH_MULTILEVEL_REPORT
2018-08-21 16:02:01.081 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 30: Switch Multi Level report, value = 21
2018-08-21 16:02:01.081 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-08-21 16:02:01.081 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 21
2018-08-21 16:02:01.081 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Updating channel state zwave:device:07cb40a2:node30:switch_dimmer to 21 [PercentType]
2018-08-21 16:02:01.086 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Commands processed 1.
2018-08-21 16:02:01.086 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@9446fef.
2018-08-21 16:02:01.087 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@9446fef.
2018-08-21 16:02:01.087 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: notifyTransactionResponse TID:26796 DONE
2018-08-21 16:02:01.088 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-08-21 16:02:21.533 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Command received zwave:device:07cb40a2:node30:switch_dimmer --> 0
2018-08-21 16:02:21.534 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 30: Creating new message for command SWITCH_MULTILEVEL_SET
2018-08-21 16:02:21.534 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
2018-08-21 16:02:21.534 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2018-08-21 16:02:21.535 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Adding to device queue
2018-08-21 16:02:21.535 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 30: Sending REQUEST Message = 01 0A 00 13 1E 03 26 01 00 25 8A 73
2018-08-21 16:02:21.540 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling intialised at 1800 seconds - start in 15000 milliseconds.
2018-08-21 16:02:21.553 [DEBUG] [org.openhab.binding.zwave.internal.protocol.serialmessage.SendDataMessageClass] - NODE 30: sentData successfully placed on stack.
2018-08-21 16:02:21.553 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 26797: Transaction not completed
2018-08-21 16:02:21.564 [DEBUG] [org.openhab.binding.zwave.internal.protocol.serialmessage.SendDataMessageClass] - NODE 30: SendData Request. CallBack ID = 138, Status = Transmission complete and ACK received(0)
2018-08-21 16:02:21.564 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
2018-08-21 16:02:21.565 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Response processed after 25ms
2018-08-21 16:02:21.565 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 26797: Transaction completed
2018-08-21 16:02:21.565 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: notifyTransactionResponse TID:26797 DONE
2018-08-21 16:02:21.565 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-08-21 16:02:36.540 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling...
2018-08-21 16:02:36.540 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling zwave:device:07cb40a2:node30:switch_dimmer
2018-08-21 16:02:36.540 [DEBUG] [org.openhab.binding.zwave.internal.converter.ZWaveMultiLevelSwitchConverter] - NODE 30: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2018-08-21 16:02:36.540 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 30: Creating new message for command SWITCH_MULTILEVEL_GET
2018-08-21 16:02:36.540 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
2018-08-21 16:02:36.540 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2018-08-21 16:02:36.540 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling zwave:device:07cb40a2:node30:scene_number
2018-08-21 16:02:36.540 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Polling skipped for zwave:device:07cb40a2:node30:scene_number on COMMAND_CLASS_BASIC
2018-08-21 16:02:36.541 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Adding to device queue
2018-08-21 16:02:36.541 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 30: Sending REQUEST Message = 01 09 00 13 1E 02 26 02 25 8B 73
2018-08-21 16:02:36.552 [DEBUG] [org.openhab.binding.zwave.internal.protocol.serialmessage.SendDataMessageClass] - NODE 30: sentData successfully placed on stack.
2018-08-21 16:02:36.552 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 26798: Transaction not completed
2018-08-21 16:02:36.567 [DEBUG] [org.openhab.binding.zwave.internal.protocol.serialmessage.SendDataMessageClass] - NODE 30: SendData Request. CallBack ID = 139, Status = Transmission complete and ACK received(0)
2018-08-21 16:02:36.567 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
2018-08-21 16:02:36.567 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 26798: Transaction not completed
2018-08-21 16:02:36.577 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Application Command Request (ALIVE:DONE)
2018-08-21 16:02:36.577 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
2018-08-21 16:02:36.577 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2018-08-21 16:02:36.577 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
2018-08-21 16:02:36.577 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveCommandClass] - NODE 30: Received COMMAND_CLASS_SWITCH_MULTILEVEL V1 SWITCH_MULTILEVEL_REPORT
2018-08-21 16:02:36.577 [DEBUG] [org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 30: Switch Multi Level report, value = 58
2018-08-21 16:02:36.577 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-08-21 16:02:36.577 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 58
2018-08-21 16:02:36.577 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Updating channel state zwave:device:07cb40a2:node30:switch_dimmer to 58 [PercentType]
2018-08-21 16:02:36.580 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Commands processed 1.
2018-08-21 16:02:36.580 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@19d53a18.
2018-08-21 16:02:36.580 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@19d53a18.
2018-08-21 16:02:36.580 [DEBUG] [org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: notifyTransactionResponse TID:26798 DONE
2018-08-21 16:02:36.581 [DEBUG] [org.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
EDIT: The binding seems to be doing everything right, and the device is just sending the wrong value. By popping the air gap (essentially power cycling the device) the dimmer began sending the correct values! In case anyone sees something similar, a power cycle may resolve it. Hopefully, this is not just a temporary fix. This was occurring with Leviton VRMX and DZMX1 dimmers.
