Thanks - reported and accepted as a bug.
Another happy customer with a Kwikset 910 door lock and a Inovelli plug, just wanted to say thanks to @chris for all his work on this binding, worked pretty much out of the box .
Along the way I created a node-red / homebridge flow to use the lock from the phone and watch (last I heard no support for those homekit things in OH2 yet). Pretty nice to walk up to the house and unlock the door with your watch. If someone wants that flow, I can make that available. From what I was able to figure out is that the NRED HK node requires āCurrentPositionā and āTargetPositionā as payload items, on each ā0ā means locked and ā100ā means open, a difference between target and current yields in transition states (āClosingā, Opening").
One thing I was curious about is that the initial state of the lock is ā{ātypeā:ā0ā,āvalueā:ā0ā}ā, I also see what appears to be spurious state updates with the same values:
2018-05-16 01:11:07.413 [vent.ItemStateChangedEvent] - DoorLockStatusRaw changed from {"type":"21","value":"1"} to {"type":"0","value":"0"}
Since this state value isnāt documented in the ā914TRL Touchpad Electronic Deadboltā docu, I was wondering if this should be ignored or what it really means.
Thanks,
-Th
@chris do you know if the new security s2 layer is backward compatible? So can I include s2 devices to openhab (if they would be in the database available)?
No - S2 is a new protocol so not directly backward compatible.
However most (all!) devices will also implement S0, so there should be no problems. S2 is only very recently become a requirement for new devices (about 6 months ago from memory).
So the bottom line is that you will be able to use any device that supports S0, and that should be all devices that support S2 - at least for a long time to come.
However, using the latest binding I still cannot see the new parameter
Did it get lost somewhere?
@chris, what do you need to add new devices to the database? I received a new Technisat TechniHome RM1 smoke detector and a Technisat TechniHome Z2 power plug but as I already knew, its not in the database.
in the internet there is not really a good information, especially not in englisch (just this simple thing in german: https://www.technisat.com/de_DE/Technisches+Datenblatt/352-775/?product=9617&createpdf)
is there a way I can support you for that? or do you need the device yourself?
Please see the database guide. The system allows basically anyone to add devices - it starts by uploading the XML file that OH generates which creates the majority of information from the device. You then need to manually add parameter information as that is not downloadable from the device.
Ok I will read me into this.
Just one question: how do I know the parameters if Iām not able to get them from the device? How would you procedure with it? Contact manufacture?
First thing would be to check the manual that you hopefully got with the device. I guess the second step would be checking the manufacturers home page. And if that turned out blank Iād try googling it. Contacting the manufacturer might be the next step after that
Yes - normally itās in the manufacturers user manual. For ZW+ devices, they are also meant to be added to the ZWA website, but I know from the manufacturers that this is often not reliable.
@DanielMalmgren already did thisā¦ at least ~20 minutes. Iāll do some more research later but dont have much hope.
I also contacted the manufacture now. Lets see what they write
Hi @chris
I tried to update to the version from May 19th and changed openhab to 2.3 build #1238. I copied the .jar from the first post into the addons folder and receive this error:
2018-05-21 20:03:07.719 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.zwave-2.3.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.zwave [229]
Unresolved requirement: Import-Package: gnu.io
at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) [?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [9:org.apache.felix.fileinstall:3.6.4]
2018-05-21 20:03:07.724 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.zwave-2.3.0-SNAPSHOT.jar
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [9:org.apache.felix.fileinstall:3.6.4]
==> /log/openhab2/zwave.log <==
21-Mai-2018 20:03:07.696 [DEBUG] [org.openhab.binding.zwave ] - BundleEvent INSTALLED - org.openhab.binding.zwave
Although the last line says ābundlEvent INSTALLEDā I do not see the ZWave binding nor any Z-Wave thing.
any hints?
Herbert
Hi guys,
Iāve been trying to get connect my August lock pro for a while now and I never been able to get it to work.
I followed all the instructions I found in this thread. Iām using April 23th version of the 2.3 binding, Used Habmin to pair the lock and I always get āUnknown deviceā.
At this point Iām not sure if Iām doing something wrong during the pairing process or if there is an error in the database lock definition.
Anyone able to get an August lock connected properly?
Thanks!
the device seems to be in the database which means, that it normally should work: http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/743
You may have missed post no. 11:
The gnu.io
bundle is the serial bundle - probably it means that the serial feature isnāt installed?
Yes It is in the database. Iām wondering if there could be anything wrong with the definition though, as it still shows as Unknown device. Is there something I can try to check if itās a pairing issue or a DB issue?
What are the device ID and type that are reported in the device properties for your device?
Here are the properties of the device:
zwave_class_basic | BASIC_TYPE_ROUTING_SLAVE |
zwave_class_generic | GENERIC_TYPE_ENTRY_CONTROL |
zwave_frequent | true |
zwave_neighbours | 1,2,3,4,5,6,7,10 |
zwave_version | 1.56 |
zwave_listening | false |
zwave_plus_devicetype | NODE_TYPE_ZWAVEPLUS_NODE |
zwave_deviceid | 1 |
zwave_nodeid | 32 |
zwave_lastheal | 2018-05-22T06:25:21Z |
zwave_routing | true |
zwave_plus_roletype | ROLE_TYPE_SLAVE_SLEEPING_LISTENING |
zwave_beaming | true |
zwave_secure | true |
zwave_class_specific | SPECIFIC_TYPE_SECURE_KEYPAD_DOOR_LOCK |
zwave_manufacturer | 831 |
zwave_devicetype | 1 |
Thanks. I suspect that this device is not in the database.
What model is it? The only August lock that is in the database is the ASL-03. Your device has different IDs to the ones in the database - it might just be that we have to add your devices info to this database entry, or if your lock is different, then weāll need to create a new entry.
