Are you including database updates in the dead node test bindings?
FYI, I’ve been using the previous dead test binding since 5/31 and it is working well.
I think it should have the same database as the one without the dead node changes. I’ll look to update this tomorrow to be sure.
Thanks.
Naming is back to 2.3 instead of 2.4? Or did you post a wrong link?
As I posted somewhere else, there is some sort of issue with dependencies when changing the version and I’ve not had a chance to look at this yet. The link should be correct.
No problem, not an issue, just wanted to mention it.
I’ve only just dropped it in, but so far this looked markedly different than before. I only have 2 dead nodes out of 120, all battery powered. It had gotten up to 4, but 2 came back alive. None of the mains powered devices died. I’ll restart in an hour and see if it’s repeatable.
I also noticed 3 of my 4 minimotes seemed to not initialize, so maybe this is working now? I need to check the logs to confirm.
EDIT: I looked away for a bit and now have a bunch of dead nodes (including mains powered)…
openhab> smarthome:things list |grep zwave| grep OFFLINE| wc -l
25 25
Just for reference, the only change between the two versions is instead of only making 1 attempt during the initial PING stage, I now make 3 attempts. The rest of the binding is unchanged…
Never mind… they are still being initialized…
Got another request here.
I keep seeing that my message queue isn’t completely empty. I keep seeing a remaining NODE 255: Added to queue - size 1
all day and it makes wonder if there’s some device to not work properly or have bad routes or whatever. For some nodes, I keep seeing constant values >>1 such as NODE 10: Added to queue - size 7
, but I don’t know what these messages are.
Is there a means to see what’s actually the messages in that/those queue(s) ? If no, could you build that in ?
Not sure if it has to or can be done in the binding but thought I’d ask here first. It would probably be best to become a functional extension to habmin.
RaZberry’s zway UI has this, and it’s of tremendous help when diagnosing a zwave network status, but I obviously cannot use any 3rd party tool on a running OH instance.
Note that there is only 1 queue - so this isn’t related to the node. It’s the total number of messages currently in the queue for ALL nodes in your network. If you any have battery nodes in your network, then it’s quite likely that this number will not be 0 all that often (unless polling is set to a long duration maybe).
No - this isn’t available.
What do you suggest? Dumping the queue would add a LOT of extra logging.
I can’t think of any way that it can easily be added to HABmin - it would need some sort of REST extension to get the queue.
Does that include the broadcast ‘node’ 255, too, or is there a special count for broadcasts? If no, the following (filtered debug log for occurences of ‘queue’) looks strange to me, or does it really imply that there were 17 messages being processed between log lines 1 and 2 ?
2018-06-17 14:08:30.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 70: Added to queue - size 17
2018-06-17 14:08:31.334 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2018-06-17 14:08:31.496 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 2
2018-06-17 14:08:34.517 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 3
2018-06-17 14:08:34.699 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 4
2018-06-17 14:08:42.458 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Added to queue - size 17
2018-06-17 14:09:05.581 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2018-06-17 14:09:05.688 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2018-06-17 14:09:05.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2018-06-17 14:09:05.954 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2018-06-17 14:09:35.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2018-06-17 14:09:35.903 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2018-06-17 14:09:35.977 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2018-06-17 14:09:36.127 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2018-06-17 14:09:37.208 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 59: Added to queue - size 17
2018-06-17 14:09:37.297 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 59: Added to queue - size 17
2018-06-17 14:09:37.310 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 59: Added to queue - size 18
At the moment, there are no broadcasts or multicast messages used in the binding. The node 255 you see means it’s a controller message, and there is a separate queue for controller messages as they need to be handled a little differently.
Ok, so it’s 2 queues, with the standard one to be of most interest w.r.t. nodes to be well connected or not, for either good reason (battery) or not.
Battery nodes yes I have quite some of them. Quite often there’s some enbloc output from the binding such as the following. The nodes listed there are all battery ones and the number of nodes more or less matches the queue length.
I don’t feel comfortable with this. It may point to a zwave network problem or not, I still don’t know, but in the old times with the standard binding, my queue was mostly hovering around zero.
Any idea how to proceed in getting the queue shortened? Does it make sense to insert polling settings for these items ?
2018-06-17 14:08:35.828 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 151: listening == false, frequentlyListening == false, awake == false
2018-06-17 14:08:35.830 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 151: Node not awake!
2018-06-17 14:08:35.831 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 21: listening == false, frequentlyListening == false, awake == false
2018-06-17 14:08:35.832 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: Node not awake!
2018-06-17 14:08:35.834 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 87: listening == false, frequentlyListening == false, awake == false
2018-06-17 14:08:35.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 87: Node not awake!
2018-06-17 14:08:35.836 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 142: listening == false, frequentlyListening == false, awake == false
2018-06-17 14:08:35.838 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 142: Node not awake!
2018-06-17 14:08:35.840 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 137: listening == false, frequentlyListening == false, awake == false
2018-06-17 14:08:35.841 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 137: Node not awake!
2018-06-17 14:08:35.843 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 138: listening == false, frequentlyListening == false, awake == false
2018-06-17 14:08:35.844 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 138: Node not awake!
2018-06-17 14:08:35.845 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: listening == false, frequentlyListening == false, awake == false
2018-06-17 14:08:35.847 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Node not awake!
2018-06-17 14:08:35.848 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: listening == false, frequentlyListening == false, awake == false
2018-06-17 14:08:35.849 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Node not awake!
2018-06-17 14:08:35.850 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 149: listening == false, frequentlyListening == false, awake == false
2018-06-17 14:08:35.852 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 149: Node not awake!
Yes please. Since I assume that’ll be quite some work, I don’t hope for this to be implemented right away, but please consider putting that on your TODO list. Would that require any work outside binding+habmin, too ?
In the “old days” there were separate queues for battery devices - now it’s all one queue. This doesn’t change the way it works though - it’s just that now there’s a logging entry that shows the queue length. I’ll remove the log entry, and then it will be less concerning .
Why do you want to shorten the queue? I don’t really understand what you think the problem is? It is perfectly normal to have messages queued to be sent to sleeping devices .
What settings do you want to change? If you want to change the poll time, then you can do this - or is there something else you want to change?
Ok, so what you’re saying is that there’s only (non timing-critical) messages to battery devices waiting in the queue, to be processed when those devices wake up. So my zwave network is alright ? That’s what I am concerned about, and if I now understood you correctly, what I observe is right what is to be expected. Still a bit of guessing as I don’t see the queue contents, but ok.
Still a bit unsure about changing settings, though.
Now regarding polling times, after some runtime, I’ve also seen the queue to grow to about two times the number of battery devices. Will a polling interval to be less than the wakeup interval result in additional messages in the queue or will it be dropped whene there’s already a message waiting to be sent to that node?
If the former I guess it would make sense to set per-device poll intervals to match that device’s wake up interval, right ?
For battery devices, this is the only type of message. Since battery devices only wake up every hour or so (depending on configuration) all messages are queued until the device wakes - nothing is time critical by definition. Time critical battery devices (eg locks) need to use FLIRS).
From what I can tell from what you’ve said, I don’t see any issues.
Yes - it will grow to fill the number of channels. Given that most devices have more than one channel, this is normal. Eg a multisensor with temperature, illuminance, humidity may have 3 messages queued - possibly another for battery state etc…
The queue avoids duplicate messages, so it won’t continue to grow with more polling.
This is not necessary. When a message is added to the queue, there is a check done to see if the same command is already in the queue. If it is, the OLD message is removed and the new one added.
Does it include the latest database data? I can’t see there changes related to version “0” issue that I made recently.
I don’t think I’ve done a database update on the dev branch since then. I’ll try and do one tonight.
Just thought I’d mention that moving from the 07/MAY/18 release to the 04/JUN/18 release breaks “Scene numbers” being received from Fibaro Dimmer 2 (FGD-212). Simply reverting the binding version makes them work again.
