I think this is it:
2018-07-10 21:25:00.756 [INFO ] [lipse.smarthome.model.script.Spotify] - Successfully got state from OpenHab: spotify_client_id
2018-07-10 21:25:28.089 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling...
2018-07-10 21:25:28.090 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling zwave:device:d4900ba9:node2:meter_reset
2018-07-10 21:25:28.090 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 2: Generating poll message for COMMAND_CLASS_METER, endpoint 0
2018-07-10 21:25:28.090 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling zwave:device:d4900ba9:node2:switch_dimmer1
2018-07-10 21:25:28.090 [DEBUG] [erter.ZWaveMultiLevelSwitchConverter] - NODE 2: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
2018-07-10 21:25:28.091 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 2: Creating new message for command SWITCH_MULTILEVEL_GET
2018-07-10 21:25:28.091 [DEBUG] [ommandClassTransactionPayloadBuilder] - At build COMMAND_CLASS_SWITCH_MULTILEVEL
2018-07-10 21:25:28.091 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Encapsulating message, endpoint 1
2018-07-10 21:25:28.091 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Encapsulating message, instance / endpoint 1
2018-07-10 21:25:28.092 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 2: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2018-07-10 21:25:28.092 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2018-07-10 21:25:28.092 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2018-07-10 21:25:28.092 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling skipped for zwave:device:d4900ba9:node2:switch_dimmer1 on COMMAND_CLASS_BASIC
2018-07-10 21:25:28.092 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling zwave:device:d4900ba9:node2:meter_kwh1
2018-07-10 21:25:28.092 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 2: Generating poll message for COMMAND_CLASS_METER, endpoint 1
2018-07-10 21:25:28.093 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 2: Generating poll message for COMMAND_CLASS_METER, endpoint 1
2018-07-10 21:25:28.093 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 2: Creating new message for application command METER_GET
2018-07-10 21:25:28.093 [DEBUG] [ommandClassTransactionPayloadBuilder] - At build COMMAND_CLASS_METER
2018-07-10 21:25:28.093 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Encapsulating message, endpoint 1
2018-07-10 21:25:28.093 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Encapsulating message, instance / endpoint 1
2018-07-10 21:25:28.094 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 2: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2018-07-10 21:25:28.094 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2018-07-10 21:25:28.094 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2018-07-10 21:25:28.094 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling zwave:device:d4900ba9:node2:meter_watts1
2018-07-10 21:25:28.094 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 2: Generating poll message for COMMAND_CLASS_METER, endpoint 1
2018-07-10 21:25:28.095 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 2: Creating new message for application command METER_GET
2018-07-10 21:25:28.095 [DEBUG] [ommandClassTransactionPayloadBuilder] - At build COMMAND_CLASS_METER
2018-07-10 21:25:28.095 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Encapsulating message, endpoint 1
2018-07-10 21:25:28.095 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Encapsulating message, instance / endpoint 1
2018-07-10 21:25:28.095 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 2: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2018-07-10 21:25:28.096 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2018-07-10 21:25:28.096 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2018-07-10 21:25:28.096 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
2018-07-10 21:25:28.096 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false
2018-07-10 21:25:28.096 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 02 06 60 0D 01 01 26 02 25 6A E3
2018-07-10 21:25:28.097 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 0D 00 13 02 06 60 0D 01 01 26 02 25 6A E3
2018-07-10 21:25:28.097 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2018-07-10 21:25:28.097 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 124: Transaction Start type SendData
2018-07-10 21:25:28.098 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
2018-07-10 21:25:28.098 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false
2018-07-10 21:25:28.098 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2018-07-10 21:25:28.098 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-07-10 21:25:28.099 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-07-10 21:25:28.099 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-07-10 21:25:28.099 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 124: [WAIT_RESPONSE] requiresResponse=true callback: 106
2018-07-10 21:25:28.099 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2018-07-10 21:25:28.099 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-10 21:25:28.099 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false
2018-07-10 21:25:28.100 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false
2018-07-10 21:25:28.105 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2018-07-10 21:25:28.105 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-07-10 21:25:28.105 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-07-10 21:25:28.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-07-10 21:25:28.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 124: [WAIT_RESPONSE] requiresResponse=true callback: 106
2018-07-10 21:25:28.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-07-10 21:25:28.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 124: [WAIT_RESPONSE] requiresResponse=true callback: 106
2018-07-10 21:25:28.106 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-07-10 21:25:28.106 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: sentData successfully placed on stack.
2018-07-10 21:25:28.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 124: Advanced to WAIT_REQUEST
2018-07-10 21:25:28.107 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 124: Transaction not completed
2018-07-10 21:25:28.107 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-10 21:25:28.107 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false
2018-07-10 21:25:28.121 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 6A 00 00 02 83
2018-07-10 21:25:28.122 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=106, payload=6A 00 00 02
2018-07-10 21:25:28.122 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Request[0], dest=0, callback=106, payload=6A 00 00 02
2018-07-10 21:25:28.122 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=106, payload=6A 00 00 02
2018-07-10 21:25:28.122 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 124: [WAIT_REQUEST] requiresResponse=true callback: 106
2018-07-10 21:25:28.123 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-07-10 21:25:28.123 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 124: [WAIT_REQUEST] requiresResponse=true callback: 106
2018-07-10 21:25:28.123 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 124: (Callback 106)
2018-07-10 21:25:28.123 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2018-07-10 21:25:28.123 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 124: callback 106
2018-07-10 21:25:28.123 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=106, payload=6A 00 00 02
2018-07-10 21:25:28.124 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 106, Status = Transmission complete and ACK received(0)
2018-07-10 21:25:28.124 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2018-07-10 21:25:28.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 124: Advanced to WAIT_DATA
2018-07-10 21:25:28.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 124: Transaction not completed
2018-07-10 21:25:28.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-10 21:25:28.125 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false
2018-07-10 21:25:28.133 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 02 07 60 0D 01 01 26 03 2D 96
2018-07-10 21:25:28.134 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 07 60 0D 01 01 26 03 2D
2018-07-10 21:25:28.135 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 07 60 0D 01 01 26 03 2D
2018-07-10 21:25:28.135 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 07 60 0D 01 01 26 03 2D
2018-07-10 21:25:28.135 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-07-10 21:25:28.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2018-07-10 21:25:28.136 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2018-07-10 21:25:28.136 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2018-07-10 21:25:28.137 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
2018-07-10 21:25:28.137 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2018-07-10 21:25:28.137 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2018-07-10 21:25:28.137 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 2: Switch Multi Level report, value = 45
2018-07-10 21:25:28.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-07-10 21:25:28.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 45
2018-07-10 21:25:28.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:d4900ba9:node2:switch_dimmer1 to 45 [PercentType]
2018-07-10 21:25:28.140 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2018-07-10 21:25:28.140 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@18e09cb4.
2018-07-10 21:25:28.140 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@18e09cb4.
2018-07-10 21:25:28.140 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: notifyTransactionResponse TID:124 DONE
2018-07-10 21:25:28.140 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-07-10 21:25:28.141 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2018-07-10 21:25:28.141 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-07-10 21:25:28.141 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-10 21:25:28.141 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false
2018-07-10 21:25:28.141 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0E 00 13 02 07 60 0D 01 01 32 01 00 25 6B F7
2018-07-10 21:25:28.142 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 0E 00 13 02 07 60 0D 01 01 32 01 00 25 6B F7
2018-07-10 21:25:28.142 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2018-07-10 21:25:28.142 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 125: Transaction Start type SendData
2018-07-10 21:25:28.143 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2018-07-10 21:25:28.143 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-07-10 21:25:28.143 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-07-10 21:25:28.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-07-10 21:25:28.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 125: [WAIT_RESPONSE] requiresResponse=true callback: 107
2018-07-10 21:25:28.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2018-07-10 21:25:28.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-10 21:25:28.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false
2018-07-10 21:25:28.150 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2018-07-10 21:25:28.150 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-07-10 21:25:28.150 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-07-10 21:25:28.150 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-07-10 21:25:28.151 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 125: [WAIT_RESPONSE] requiresResponse=true callback: 107
2018-07-10 21:25:28.151 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-07-10 21:25:28.151 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 125: [WAIT_RESPONSE] requiresResponse=true callback: 107
2018-07-10 21:25:28.151 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-07-10 21:25:28.151 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: sentData successfully placed on stack.
2018-07-10 21:25:28.151 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 125: Advanced to WAIT_REQUEST
2018-07-10 21:25:28.152 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 125: Transaction not completed
2018-07-10 21:25:28.152 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-10 21:25:28.152 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false
2018-07-10 21:25:28.166 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 6B 00 00 02 82
2018-07-10 21:25:28.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=107, payload=6B 00 00 02
2018-07-10 21:25:28.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Request[0], dest=0, callback=107, payload=6B 00 00 02
2018-07-10 21:25:28.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=107, payload=6B 00 00 02
2018-07-10 21:25:28.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 125: [WAIT_REQUEST] requiresResponse=true callback: 107
2018-07-10 21:25:28.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-07-10 21:25:28.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 125: [WAIT_REQUEST] requiresResponse=true callback: 107
2018-07-10 21:25:28.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 125: (Callback 107)
2018-07-10 21:25:28.168 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2018-07-10 21:25:28.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 125: callback 107
2018-07-10 21:25:28.168 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=107, payload=6B 00 00 02
2018-07-10 21:25:28.168 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 107, Status = Transmission complete and ACK received(0)
2018-07-10 21:25:28.169 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2018-07-10 21:25:28.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 125: Advanced to WAIT_DATA
2018-07-10 21:25:28.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 125: Transaction not completed
2018-07-10 21:25:28.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-10 21:25:28.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false
2018-07-10 21:25:28.179 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 02 0E 60 0D 01 01 32 02 21 44 00 00 00 0A 00 00 D1
2018-07-10 21:25:28.180 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 0E 60 0D 01 01 32 02 21 44 00 00 00 0A 00 00
2018-07-10 21:25:28.180 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 0E 60 0D 01 01 32 02 21 44 00 00 00 0A 00 00
2018-07-10 21:25:28.180 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 0E 60 0D 01 01 32 02 21 44 00 00 00 0A 00 00
2018-07-10 21:25:28.181 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-07-10 21:25:28.181 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2018-07-10 21:25:28.181 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2018-07-10 21:25:28.181 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2018-07-10 21:25:28.181 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_METER, endpoint 1
2018-07-10 21:25:28.182 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY NOT required on COMMAND_CLASS_METER
2018-07-10 21:25:28.182 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_METER V3 METER_REPORT
2018-07-10 21:25:28.182 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 2: Meter: Type=Electric(1), Scale=kWh(0), Value=0.1
2018-07-10 21:25:28.182 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveMeterValueEvent
2018-07-10 21:25:28.182 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_METER, value = 0.1
2018-07-10 21:25:28.183 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:d4900ba9:node2:meter_kwh1 to 0.1 [DecimalType]
2018-07-10 21:25:28.184 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2018-07-10 21:25:28.184 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@468c30ec.
2018-07-10 21:25:28.184 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@468c30ec.
2018-07-10 21:25:28.184 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: notifyTransactionResponse TID:125 DONE
2018-07-10 21:25:28.189 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-07-10 21:25:28.189 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2018-07-10 21:25:28.190 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-07-10 21:25:28.190 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-10 21:25:28.190 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false
2018-07-10 21:25:28.190 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0E 00 13 02 07 60 0D 01 01 32 01 10 25 6C E0
2018-07-10 21:25:28.190 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 0E 00 13 02 07 60 0D 01 01 32 01 10 25 6C E0
2018-07-10 21:25:28.191 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2018-07-10 21:25:28.191 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 126: Transaction Start type SendData
2018-07-10 21:25:28.192 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2018-07-10 21:25:28.192 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-07-10 21:25:28.192 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-07-10 21:25:28.192 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-07-10 21:25:28.193 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 126: [WAIT_RESPONSE] requiresResponse=true callback: 108
2018-07-10 21:25:28.193 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2018-07-10 21:25:28.193 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-10 21:25:28.193 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false
2018-07-10 21:25:28.199 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2018-07-10 21:25:28.199 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-07-10 21:25:28.199 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-07-10 21:25:28.199 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-07-10 21:25:28.199 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 126: [WAIT_RESPONSE] requiresResponse=true callback: 108
2018-07-10 21:25:28.199 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-07-10 21:25:28.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 126: [WAIT_RESPONSE] requiresResponse=true callback: 108
2018-07-10 21:25:28.200 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-07-10 21:25:28.200 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: sentData successfully placed on stack.
2018-07-10 21:25:28.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 126: Advanced to WAIT_REQUEST
2018-07-10 21:25:28.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 126: Transaction not completed
2018-07-10 21:25:28.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-10 21:25:28.201 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false
2018-07-10 21:25:28.215 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 6C 00 00 02 85
2018-07-10 21:25:28.215 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=108, payload=6C 00 00 02
2018-07-10 21:25:28.216 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Request[0], dest=0, callback=108, payload=6C 00 00 02
2018-07-10 21:25:28.216 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=108, payload=6C 00 00 02
2018-07-10 21:25:28.216 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 126: [WAIT_REQUEST] requiresResponse=true callback: 108
2018-07-10 21:25:28.216 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-07-10 21:25:28.216 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 126: [WAIT_REQUEST] requiresResponse=true callback: 108
2018-07-10 21:25:28.216 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 126: (Callback 108)
2018-07-10 21:25:28.217 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2018-07-10 21:25:28.217 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 126: callback 108
2018-07-10 21:25:28.217 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=108, payload=6C 00 00 02
2018-07-10 21:25:28.217 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 108, Status = Transmission complete and ACK received(0)
2018-07-10 21:25:28.217 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2018-07-10 21:25:28.218 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 126: Advanced to WAIT_DATA
2018-07-10 21:25:28.218 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 126: Transaction not completed
2018-07-10 21:25:28.218 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-10 21:25:28.218 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false
2018-07-10 21:25:28.228 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 04 00 02 0C 60 0D 01 01 32 02 21 32 00 8A 00 00 23
2018-07-10 21:25:28.228 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 0C 60 0D 01 01 32 02 21 32 00 8A 00 00
2018-07-10 21:25:28.228 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 0C 60 0D 01 01 32 02 21 32 00 8A 00 00
2018-07-10 21:25:28.229 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 0C 60 0D 01 01 32 02 21 32 00 8A 00 00
2018-07-10 21:25:28.229 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-07-10 21:25:28.229 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2018-07-10 21:25:28.229 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2018-07-10 21:25:28.230 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2018-07-10 21:25:28.230 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_METER, endpoint 1
2018-07-10 21:25:28.230 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY NOT required on COMMAND_CLASS_METER
2018-07-10 21:25:28.230 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_METER V3 METER_REPORT
2018-07-10 21:25:28.230 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 2: Meter: Type=Electric(1), Scale=W(2), Value=13.8
2018-07-10 21:25:28.231 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveMeterValueEvent
2018-07-10 21:25:28.231 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_METER, value = 13.8
2018-07-10 21:25:28.231 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:d4900ba9:node2:meter_watts1 to 13.8 [DecimalType]
