chris
(Chris Jackson)
July 15, 2018, 1:40pm
3297
mhilbush:
Yes, I think we had that discussion in an email, IIRC. And, yes, it was related to the Minimote.
Ah - ok, that’s probably why I can’t find it - I didn’t look there .
Note that you might need to reinitialise the thing to have the control classes correctly reflected…
mhilbush:
I also was wondering about how you handle the ADD_NODE_STATUS_ADDING_CONTROLLER response when including a controller. It didn’t look like you were processing (i.e. adding as supported) the command classes that are reported in that message (similar to the NIF). That was a couple weeks back, so I’m not sure if that has changed in the binding.
Nothing has changed, but the controller should be added in the same way as if it was a slave -:
case IncludeControllerFound:
case IncludeSlaveFound:
startTimer(TIMER_MAIN);
// When a device is found we get the IncludeSlaveFound notification.
// Here we need to end inclusion.
logger.debug("NODE {}: Including node.", incEvent.getNodeId());
is the event that is sent when ADD_NODE_STATUS_ADDING_CONTROLLER
is received -:
case ADD_NODE_STATUS_ADDING_CONTROLLER:
if (incomingMessage.getMessagePayloadByte(2) < 1 || incomingMessage.getMessagePayloadByte(2) > 232) {
break;
logger.debug("NODE {}: Adding controller.", incomingMessage.getMessagePayloadByte(2));
zController.notifyEventListeners(new ZWaveInclusionEvent(ZWaveInclusionState.IncludeControllerFound,
incomingMessage.getMessagePayloadByte(2)));
break;
Do you have the log itself please?
mhilbush
(Mark)
July 15, 2018, 1:41pm
3298
chris:
Yes. It’ll be in your email momentarily.
chris
(Chris Jackson)
July 15, 2018, 1:53pm
3300
Thanks - I’ve found the issue. It should be quick to fix…
mhilbush
(Mark)
July 15, 2018, 1:54pm
3301
chris:
Awesome! I’ll wait for that version to test.
chris
(Chris Jackson)
July 15, 2018, 1:59pm
3302
I’ve just updated it - let me know how it looks…
mhilbush
(Mark)
July 15, 2018, 2:16pm
3303
Unrelated question…
Did you remove the neighbor update from the initialization?
This is the cleanest startup I’ve ever seen.
chris
(Chris Jackson)
July 15, 2018, 2:17pm
3304
Yes - I’ve remove a bunch of “unnecessary” stuff from the initialisation.
sihui
(SiHui)
July 15, 2018, 2:19pm
3305
chris:
The latest version from the link at the top of this thread now includes this.
No issues (dead nodes or something) on a small network with 21 devices (6 battery powered, 15 mains powered) running on an RPi3 booting from an SSD.
As always; thanks a lot
mhilbush
(Mark)
July 15, 2018, 2:41pm
3306
chris:
I started by excluding the minimote node, factory resetting it, then including it. The inclusion worked, and it completed initialization.
However, when a scene button is pressed, it’s complaining that SCENE_ACTIVATION command class is not supported.
Did your change to deal with the control command classes result in inbound control command class messages being unknown? Here’s a snippet. Let me know if you want a full log.
2018-07-15 10:30:04.040 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 64 04 2B 01 01 00 BA
2018-07-15 10:30:04.040 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=100, callback=0, payload=00 64 04 2B 01 01 00
2018-07-15 10:30:04.041 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=100, callback=0, payload=00 64 04 2B 01 01 00
2018-07-15 10:30:04.041 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=100, callback=0, payload=00 64 04 2B 01 01 00
2018-07-15 10:30:04.041 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-07-15 10:30:04.041 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 100: Application Command Request (ALIVE:DONE)
2018-07-15 10:30:04.041 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 100: resetResendCount initComplete=true isDead=false
2018-07-15 10:30:04.041 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 100: Incoming command class COMMAND_CLASS_SCENE_ACTIVATION, endpoint 0
2018-07-15 10:30:04.041 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 100: Command class COMMAND_CLASS_SCENE_ACTIVATION not found.
2018-07-15 10:30:04.041 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 100: Commands processed 1.
2018-07-15 10:30:04.041 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 100: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@333f9074.
2018-07-15 10:30:04.042 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-07-15 10:30:04.042 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-15 10:30:04.042 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false
2018-07-15 10:30:41.561 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 64 04 2B 01 01 00 BA
2018-07-15 10:30:41.561 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=100, callback=0, payload=00 64 04 2B 01 01 00
2018-07-15 10:30:41.562 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=100, callback=0, payload=00 64 04 2B 01 01 00
2018-07-15 10:30:41.562 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=100, callback=0, payload=00 64 04 2B 01 01 00
2018-07-15 10:30:41.562 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-07-15 10:30:41.562 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 100: Application Command Request (ALIVE:DONE)
2018-07-15 10:30:41.562 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 100: resetResendCount initComplete=true isDead=false
2018-07-15 10:30:41.563 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 100: Incoming command class COMMAND_CLASS_SCENE_ACTIVATION, endpoint 0
2018-07-15 10:30:41.563 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 100: Command class COMMAND_CLASS_SCENE_ACTIVATION not found.
2018-07-15 10:30:41.563 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 100: Commands processed 1.
2018-07-15 10:30:41.563 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 100: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@b9d576b.
2018-07-15 10:30:41.563 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-07-15 10:30:41.563 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-07-15 10:30:41.563 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false
chris
(Chris Jackson)
July 15, 2018, 2:46pm
3307
It shouldn’t - all I did is set a flag to say they are control classes, and then I don’t scan them for services.
chris
(Chris Jackson)
3308
Probably going to be needed I think.
chris
(Chris Jackson)
July 15, 2018, 3:01pm
3310
Got it - thanks. I’m going to head out for an hour or so but will take a look at it afterwards. It’s clear though that in this mode it has ignored the control classes - this is different than before though since it never used this data at all previously…
chris
(Chris Jackson)
July 15, 2018, 3:07pm
3311
I’ve just made an update that I think will solve it - if not, let me know and I’ll take a look when I get back…
mhilbush
(Mark)
July 15, 2018, 3:21pm
3312
chris:
Something must’ve gone wrong because I get a 404 when I click on the link in post #1 .
5iver
(Scott Rushworth)
July 15, 2018, 3:35pm
3313
LOL… I was just going to test it and I get the same.
chris
(Chris Jackson)
July 15, 2018, 5:00pm
3314
Crap - sorry. I messed up when renaming it. It should be sorted now…
mhilbush
(Mark)
July 15, 2018, 5:27pm
3315
chris:
Installed it. It did not seem to resolve the problem.
Email on the way.
5iver
(Scott Rushworth)
July 15, 2018, 6:15pm
3316
This is looking really good so far! Only one functioning but dead node, but these devices have always been a bit fiddly. I see the same issue with my minimotes that Mark reported.
