As a quick local work around I have changed to versionMax and versionMin in fibaro_fgsd002_00_000 and fgsd002_3_2.xml so that version 3.3 will use the original file. Then it works.
I would like to know if anybody has tried to add a fgsd002 version 3.3 with the latest development version (24th of July).
Please provide the XML file for your device - or some information on it. From a quick look at the database, I donāt see anything obviously wrong with the database that would cause this, and my suspicion is itās something specific to your system with respect to the change in thing uid.
By the way, is org.openhab.binding.zwave-2.4.0-SNAPSHOT.jar (24th July) now build of the master branch? I guess it must be because the change adding fgsd002_3_2.xml has not been committed to the developement branch.
Iām seeing this, but with some WALLC-S switches - running OH #1318 and zwave binding 2.4.0.201807242215.
I think these also got updated recently in the zwave database.
Here is the xml file: network_f1e8718f__node_29.xml (14.2 KB)
EDIT:
Found some warning message in the log:
19:33:38.645 [WARN ] [ig.discovery.internal.PersistentInbox] - Cannot create thing. No binding found that supports creating a thing of type zwave:zwaveme_wallcs_00_000.
any changes with the Fibaro Door/Window Sensor 2 (FGDW-002) ?
I actually try the DevBinding 2.4.0 from 24th July - The Sensor give me a:
2018-07-26 21:38:41.464 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! Manufacturer data not known.
ā¦ now with 2.4.0 - Manufactrer data not known ?! ā¦ hmā¦
This means that the binding hasnāt downloaded the manufacturer data from the device. You need to wake it up so it can initialise, or wait for it to wake up by itself (may take a few hours or a day or so - depending on how your system is configured).
okay - IĀ“ll try. The FGDW-002 are battery powered, so this can be a reason.
Now with the 2.4.0 dev. binding - my zwave USB Stick are new named : āZWave Plus USB Dongleā.
Is that correct ?
Even stranger - you mean it creates the XML if you change the version in the XML, and it doesnāt otherwise? Except in special cases, the thing definition in the database will not impact the protocol layers.
You need to find out why itās not creating the XML - use the debug logs.
okay, I wake up the device many times ā¦ no success.
You know this : (I get this every time I click on an thing in habmin)
2018-07-26 22:31:30.615 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
