Did you enter the serial port of the controller in the Serial Controller thing?
I had some issueās with the dimmer and the dev binding, i had to remove and add the device and that fixed everything.
I did, but it did not really accept it ? I now went back to the old
binding which works. Also if I try the new would I have to add it every
time I restart my Raspberry pi ? When is a stable release expected?
With the old binding i cannot use my Fibaro sensors.
Hi - and not wanting to chase, but just wondering if there would be a fix for this in the next few days? If not, would you mind posting a JAR before all the hold-off changes made things a little unstable?
thanks,
Dan
Iām not sure what you mean by it not accepting it. Are you saying that when you go back into HABmin after setting the serial port the serial port is not set?
ā¦okā¦ I press the + sign under Things in HABmin. I select āZ-Wave
Bindingā, Z-wave controller and press save (Nothing happens here??) I
then go to PaperUI and see the added controller under Things. I edit the
controller and insert /dev/ttyAMA0 as serial (which was the correct for
the old binding. I save and get:
Status:OFFLINE - COMMUNICATION_ERRORSerial Error: Port {0} does not exist
So this does not work.
So a Serial Controller thing doesnāt show up in HABminās Things list? Thatās really odd.
And you confirmed that /dev/ttyAMA0
exists and that there is not a permissions problem?
Can you confirm that the serial feature is installed?
Can you confirm that thereās only one version of the binding installed? In Karaf console, run this:
list -s | grep zwave
Sorry for asking what may be basic questions. In the 1.5 years of using the dev version of the binding, Iāve not come across this before.
Hi there, wondering on the ETA of the release of 2.4 zwave binding? Appreciate all your guys hard work. I have bought myself a Yale zwave front door lock and trying to get it to work with no luck. Have spent about 8 hours watching vids etc on how to manually load the binding but it is way over my head.
Kyle
No, itās not
Uninstall the zwave binding through PaperUI, download the jar from the first post in this thread, put it in your addons folder, restart openHAB.
If you get an error you need to load the serial transport:
Then delete all your things and readd them (donāt exclude your devices!).
Good luck.
Thank you for the reply. Will try again.
Normally, releases have been made every 6 months - the next one (2.4) is likely to be in December.
@chris @5iver Hereās the downside of adding these unknown classes. While I donāt think this causes any real issue, it certainly results in bogus information being added to the node.xml files.
It looks like node 43 (an Everspring ST814) lost itās mind shortly after midnight. All those unknown command classes below were added to the node.xml.
Hereās the raw log entries.
zwave.log.20180731021619:2018-07-31 00:21:53.933 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 43: Command class COMMAND_CLASS_DCP_CONFIG not found, trying to add it.
zwave.log.20180731021619:2018-07-31 00:21:54.309 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 43: Command class COMMAND_CLASS_THERMOSTAT_OPERATING_STATE not found, trying to add it.
zwave.log.20180731021619:2018-07-31 00:21:54.318 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 43: Command class COMMAND_CLASS_SECURITY_PANEL_ZONE_SENSOR not found, trying to add it.
zwave.log.20180731021619:2018-07-31 00:21:54.326 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 43: Command class COMMAND_CLASS_DCP_MONITOR not found, trying to add it.
zwave.log.20180731021619:2018-07-31 00:21:54.333 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 43: Command class COMMAND_CLASS_METER_PULSE not found, trying to add it.
zwave.log.20180731021619:2018-07-31 00:21:54.372 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 43: Command class COMMAND_CLASS_PREPAYMENT_ENCAPSULATION not found, trying to add it.
zwave.log.20180731021619:2018-07-31 00:21:54.385 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 43: Command class COMMAND_CLASS_SWITCH_TOGGLE_BINARY not found, trying to add it.
zwave.log.20180731021619:2018-07-31 00:21:54.414 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 43: Command class COMMAND_CLASS_DCP_MONITOR not found, trying to add it.
zwave.log.20180731021619:2018-07-31 00:21:54.430 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 43: Command class COMMAND_CLASS_SCHEDULE_ENTRY_LOCK not found, trying to add it.
Iāve seen similar examples from other nodes, but not as egregious as this one.
On my side, I am still unsble to setup my ST814 to report values every hour, I only got new values once a day. I captured the logs when I change the setting through Paper UI. I will provide them this evening.
Yes - this is exactly why I implemented the change. However, while these are not nice in the XML, they also donāt cause any problem with the binding operation.
If we leave this change in, then we need to ensure that all command classes that devices support, but donāt report in their NIF, are added to the database, otherwise devices wonāt work as they used to. Remember that it has worked this way since the very first version of the binding (ie in OH1) around 2013 if I remember correctly.
This must be related to associations, or device configuration. Have you tried a reinitialisation of the device - is there a log of the reinitialisation?
Agreed. Only one exception, and it may be a pretty minor one. If one of these node.xml files was uploaded to the DB in order to create a new device in the database, wonāt the DB entry be created with a bunch of bogus command classes? And, itās unlikely the user would know which ones were legit and which ones were bogus. And, even if they did know, they would need to ask you to delete the bogus ones. Like I said, I think thatās a pretty minor issue in the whole scheme of things.
On the plus side, the node.xml can be cleaned up by doing a reinit.
My devices are set up to auto report every 30 minutes. If you want to PM me, I can walk you through the exact configuration I have in my devices.
I think Kyle meant the merging of the dev branch into the master branch so that al these fixed would join the daily snapshots. And i thought Kai wanted to do some smaller milestone like releases. imho this refactored z-wave binding would be big enough for such a release.
Just added a new z-wave door sensor device to Chrisā database. Outside of waiting for the next jar file, is there another way to have the new device (which is now included in the database) get recognized in my local openhab install? Thanks!
If youāre really antsy to use itā¦
