Is Habmin packaged with 2.4 snapshots compatible with the dev version of the binding from this topic ? If not, where can I donwload the compatible jar for Habmin ?
By the way, I will check with Firefox tools what REST API are called by Paper UI.
I can see that all parameters are of this kind config_X_1 lexcept the 6th which is the one I am trying to set which is config_6_2. Is it normal ?
NODE 4: Configuration update set config_1_1 to 99
NODE 4: Configuration update set config_2_1 to 99
NODE 4: Configuration update set config_6_2 to 0
NODE 4: Configuration update set config_7_1 to 0
NODE 4: Configuration update set config_8_1 to 0
NODE 4: Configuration update set config_3_1 to 99
NODE 4: Configuration update set config_4_1 to 99
NODE 4: Configuration update set config_5_1 to 99
I’ve had a few Fibaro Dimmers (FGD-212) working pretty fine. These had firmware 3.4.
I’ve added another, which happens to have firmware 3.5 (although not sure this is significant) and the Scene numbers don’t appear to be being received by Openhab (configuration parameter is set on device).
2018-08-15 11:10:48.230 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Incoming command class COMMAND_CLASS_SCENE_ACTIVATION, endpoint 0
2018-08-15 11:10:48.231 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Command class COMMAND_CLASS_SCENE_ACTIVATION not found.
Any ideas?
Edit: just seen some similar issues earlier in the thread. Looks like I need to make sure I’m running the latest binding and re-include. The strange thing is, I think the only factor changing is the device firmware version. The software versions I’m using haven’t been changed since I set up with the existing dimmers…
There’s a separate database entry for devices with the 3.5 firmware, so that could be the cause for why the 3.5 device is being handled differently. Up to version 3.4 Version 3.5 and later
Both database entries have an entry for SCENE_ACTIVATION in endpoint 0, so it’s not obvious to me why it’s not being handled for the 3.5 device.
It looks like SCENE_ACTIVATION was added in a commit on June 26. If your version is older than that, then you need to pick up the latest version of the binding.
I think my zwave stick my have died, \ trying to figure out how I can tell for sure
I have been running 2.3.0.201805192224 for a few weeks now without issue. Sometime within the past few days, my zwave devices have stopped responding.
BasicUI shows the zwave controller as OFFLINE and I see multiple messages in the logs that look rather ominous:
8-15 08:07:03.642 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 31: Command received zwave:device:15bfa0704b9:node31:switch_binary → OFF
2018-08-15 08:07:03.642 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2018-08-15 08:11:05.037 [DEBUG] [g.zwave.internal.ZWaveConfigProvider] - ZWave product zwave:serial_zstick has no references!
2018-08-15 08:11:05.037 [DEBUG] [g.zwave.internal.ZWaveConfigProvider] - ZWave product zwave:device has no references!
2018-08-15 08:11:05.043 [DEBUG] [g.zwave.internal.ZWaveConfigProvider] - ZWave product zwave:serial_zstick has no references!
2018-08-15 08:11:05.043 [DEBUG] [g.zwave.internal.ZWaveConfigProvider] - ZWave product zwave:device has no references!
I did some basics checks to ensure ttyUSB0 is showing on the filesystem, restarted openhab, restarted the machine, but the behavior is consistent.
Hi Dave,
There’s nothing at all being received from the device as far as I can see, so either it’s dead, or there’s a serial port issue or something fundamental like that…
@mstormi, @digitaldan - are your systems still holding up? Have you had any more Queue Full issues? If not, I might merge the hold-off code as previously I think you weren’t going more than a day without this issue showing up?
Yes, mine’s running fine since I installed your Aug12th binding 2 days ago and yes, with holdoff-enabled versions before I got ‘queue full’ after 24hrs at most. What do you mean by ‘merge holdoff’ now - isn’t that already in there ?
Yes things look very good, no issues performance wise . As for the threads, I went ahead and installed the most recent version with thread naming , there definitely is a pattern with nodes above a certain number getting stuck during the heal phase , just hopped on a plane but as soon as I have a ssh connection I will post another thread dump and log file.
Updating the binding resolved the Scene Number issue with the firmware version 3.5 Fibaro dimmer.
The bit I don’t understand is that the new “thing” (with version 3.5 firmware) always had the “Scene Number” channel even before I installed the updated binding. My expectation would be if this was missing from the database for the version 3.5 firmware then it should be entirely missing as a channel?
