For most devices, this is not necessary, and not recommended. For the devices I’ve tested, including the BE469 that I have, it was certainly not necessary.
Maybe there are some old devices out there that still need this, but it should be the exception rather than the rule (still worth keeping in mind if things don’t work ).
Yes, I understand. I just wanted to emphasize that you may think you are close enough to the controller, but you may not be. Over 20 tries at 20cm did not work. The first try at 1cm worked. FWIW, my other same model lock securely included at a distance of ~ 1m.
@peter_oh what controller do you have? The only thing that looks a little strange in your log is that the call to end the inclusion mode times out. This doesn’t happen on my stick. This might indicate something strange with the controller, or, the delay might cause the secure inclusion to time out (although I don’t think so as it’s still only waiting about 8 seconds after the initial inclusion before the key exchange starts, but it’s still a little close to the edge if the specific lock is maybe also a little on the “quick” side).
Otherwise, all looks ok.
I will see if I can reduce the timeout on the last call to see if that helps…
If you trigger on received update and your FGMS config parameters are set for example wrong, that resetting can happen very easily.
So the only chance to get any help is to:
post your rules
post a debug log from where motion begins
provide info WHICH FGMS your are using (parameters can be different between firmware versions)
Pardon?
Do you run the binding that this thread is about (development version), or do you run the version that comes with the 2.4.0 snapshot ?
This thread is about that binding, so may I kindly ask you to open another thread first and get your issue sorted out there?
And you should post your rules, items and zwave debug level logs, otherwise noone will be able to help.
Eventually come back here when you have reason to believe that there’s a misbehavior in the (development version) binding (I don’t think it is).
I am running the development snapshot as of August 27th. (Had to go into karaf and remove the snapshot bundle for zwave and enable the addon/development jar, so yes I am running the “development” snapshot).
Anyway, I got my BE469 lock to securely join and I added a bunch of switches and a couple sensors after getting BE469 securely added. Yesterday I added a couple Aeotec dual channel power meters. It is reading the meters sensor values, but now my switches are intermittently working. Sometimes I send on on/off command to a thing for a switch item and it works. Sometimes it doesn’t.
In Habmin, the thing will intermittently no longer show active channels and the switch item isn’t showing.
In my openhab.log file, I see references to nodes that do not exist! I only have 29 total devices/nodes. My log file is sometimes jumping as high as Node 148!
ls -la /var/lib/openhab2/zwave
total 324
drwxr-xr-x 2 openhab openhab 4096 Aug 29 10:11 .
drwxr-xr-x 11 openhab openhab 4096 Aug 24 23:22 ..
-rw-r--r-- 1 openhab openhab 6063 Aug 31 02:32 network_ea85d234__node_10.xml
-rw-r--r-- 1 openhab openhab 6624 Aug 31 02:36 network_ea85d234__node_11.xml
-rw-r--r-- 1 openhab openhab 6625 Aug 31 02:38 network_ea85d234__node_12.xml
-rw-r--r-- 1 openhab openhab 10291 Aug 30 21:28 network_ea85d234__node_13.xml
-rw-r--r-- 1 openhab openhab 9857 Aug 30 21:23 network_ea85d234__node_14.xml
-rw-r--r-- 1 openhab openhab 10478 Aug 31 02:39 network_ea85d234__node_15.xml
-rw-r--r-- 1 openhab openhab 17869 Aug 31 02:39 network_ea85d234__node_16.xml
-rw-r--r-- 1 openhab openhab 9821 Aug 31 02:39 network_ea85d234__node_17.xml
-rw-r--r-- 1 openhab openhab 9821 Aug 30 21:23 network_ea85d234__node_18.xml
-rw-r--r-- 1 openhab openhab 3348 Aug 31 02:35 network_ea85d234__node_1.xml
-rw-r--r-- 1 openhab openhab 22550 Aug 31 02:38 network_ea85d234__node_20.xml
-rw-r--r-- 1 openhab openhab 24742 Aug 30 20:29 network_ea85d234__node_26.xml
-rw-r--r-- 1 openhab openhab 20111 Aug 31 02:36 network_ea85d234__node_28.xml
-rw-r--r-- 1 openhab openhab 19674 Aug 31 02:34 network_ea85d234__node_29.xml
-rw-r--r-- 1 openhab openhab 13078 Aug 8 14:34 network_ea85d234__node_2.xml
-rw-r--r-- 1 openhab openhab 24624 Aug 31 02:34 network_ea85d234__node_3.xml
-rw-r--r-- 1 openhab openhab 7083 Aug 31 02:37 network_ea85d234__node_4.xml
-rw-r--r-- 1 openhab openhab 6921 Aug 31 02:37 network_ea85d234__node_5.xml
-rw-r--r-- 1 openhab openhab 6868 Aug 31 02:37 network_ea85d234__node_6.xml
-rw-r--r-- 1 openhab openhab 13698 Aug 31 02:37 network_ea85d234__node_7.xml
-rw-r--r-- 1 openhab openhab 13673 Aug 30 15:19 network_ea85d234__node_8.xml
-rw-r--r-- 1 openhab openhab 13690 Aug 30 15:19 network_ea85d234__node_9.xml
Is there some other switches I can set to get more ZWave debug output to help troubleshoot this issue?
If I restart the openhab service, my control of devices works for a couple minutes until it stops.
You could put the binding into debug mode, which will generate substantially more information about what’s going on. In the karaf console, you can type the following to go into debug mode.
log:set DEBUG org.openhab.binding.zwave
And the following to get it out of debug mode.
log:set INFO org.openhab.binding.zwave
That’s strange. Hopefully debug mode will shed some light about what’s going on.
The data get serialised after the heal, and also after any configuration change.
Probably not. Normally there should be a file for every node once it has completed the initialisation (ie the interrogation phase, where the binding reads a load of information out of the device that describes all the features it provides.
Minimotes can be hard to get to complete initialization. Since they don’t wake up on their own, you need to wake them up manually, sometimes repeatedly.
Press and hold the button labeled “Learn” for 3 seconds – The Minimote will stay awake for 30 seconds.
jwiseman
(Mr. Wiseman (OH 4.2 Snapshot on Pi4))
4122
First off, the new binding is a huge leap forward on zWave front.
Here’s how I resolved this with the new binding with the same 4 devices being UNKNOWN.
deleted the 4 offline zWave devices via paper ui
shut down OH2.3
copied the 1 XML file that was working /userdata/zwave and made 4 others changing the name of the node for each file name
edited each XML file and changed the node to match the file name node (you may have to pull the XML file out of /userdata/zwave to edit it because the directory is pretty locked down for edits)
deleted and recreated the /userdata/cache & /userdata/tmp folders
reboot NAS
started up OH2.3
waited for paper ui to start and went into and the 4 nodes were defined correctly now
