Does that mean that this is also resolved?
Thanks for all you hard work,
I will test and report back, thanks,
br,
Raymond
br,
Raymond
Unfortunately, no - sorry. This one needs some more thought to introduce a workaround to the responses this device is sending.
Thereās no reason to be sorry, you are doing a great job!
btw, do you want me to make a GitHub ticket for the SIS parameter?
br,
Raymond
Thanks.
Yes please - then itās on my radar
Of course. Ticket submitted.
Do we need to reinclude devices of this type to take advantage of the changes?
No - you should just need to update the binding.
Great, thanks.
Hey @chris! Been away from this for a while. Wow this thread is longā¦
Just installed the latest version, which is running well on my test platform.
Iāve been holding off on installing this on any of my prod systems until thereāll be no more breaking changes. Do you anticipate any more breaking changes?
BTW, I like the new STATE_UPDATE entries in the log viewer. Very helpful!
when using High Power inclusion from HABmin i get:
zwave.event.inclusion_failed
in orange
Do I need to use OpenHab 2.1.0 to test newest version of binding published today?
If so, is it enough to use beta channel (echo ādeb http://dl.bintray.com/openhab/apt-repo2 testing mainā | sudo tee /etc/apt/sources.list.d/openhab2.list) ?
I hope you read it all - there will be a test later
Iām trying to avoid it, but yes, at some stage there will be. I suspect that it will be a little while away though, but I still need to implement the dynamic channels. So, I think itās stable for the next few months at leastā¦
My immediate plan is to iron out the major issues now, and get this merged to master after the next release (not exactly sure when that is, but I guess soonish).
Thatās sad ;). Iām not really sure what it means - probably the controller returned an error that inclusion failed, but other than that, Iām not sure as thereās no further information (I think).
I think it is probably wise although Iām not 100% sure itās needed. I canāt remember if there have been additions to the ESH/OH core or not, but to be safe, letās say yes ;).
I guess thatās enough for the framework, but you still need to install this binding manually - see toward the top of this thread for installation info (about 6 messages down I think).
Guaranteed to fail! LOL
Ok, Iāll put it on the one prod system that still has a small number of nodes. The other prod system has about 30+ nodes and is about to have another 20 or so dimmers and a few more battery devices added to it.
One thing I just noticed for all my battery devices with temp sensors (ZW100, ST814, and FGMS001)ā¦ In HABmin, when I change the scale to Fahrenheit on the Temperature channel, it doesnāt seem to work. HABmin still reports it as C in the channel panel (after refreshing page), and I see in the log that the binding is not converting the reported temp to F. Is this a known issue?
Deleted node xml and deleted/readded things.
Looking at the Thing JSON for those nodes, they show this after changing the scale from C to F. Shouldnāt that be a 1?
"label": "Sensor (temperature)",
"configuration": {
"properties": {
"config_scale": "0"
Edit: Looks like it might be a HABmin issue. It worked when I changed it with PaperUI.
"configuration": {
"properties": {
"config_scale": "1"
The reason for this is this is a notification report - not an alarm and the code I added was for alarms since alarms are not standardised within the ZWave standardā¦
Notifications are handled differently and should already support this if the type is decimal. What I donāt understand is why this is an OnOff type where it should be a decimal type according to the channel.xml file in the binding. Maybe something somewhere is remembering an old definition?
Any thoughts on how you did this? I am running the latest OH2 Z-Wave binding. Iāve tried pairing at this point at least 20 times - every time secure inclusion fails.
@chris So I just included my 914 and donāt see the new Alarm # Channel, just the general alarm channel in HABmin. So I went to follow @whwkins lead and add the channel to the xml file but I donāt see an xml file for the new node? I see all my other nodes that I created earlier but not for the new one I just added?
Also, is there an edit in the database to make the alarm number channel come through vs editing the xml?
Thanks as always for all the work.
It doesnāt seem to have been added to the database yet -:
You canāt add anything to the XML file - if you want to add it manually, then you need to edit the XML file in the JAR.
Iām not sure what you mean by this?
You answered that with the first one. Iām afraid to try to do a direct edit to the database since the last time I did I broke one of the Cooper switches (which as a tangential I donāt think ever got rolled back). Iām happy to try again thoughā¦
Makes sense, though is it an issue that the node xml file didnāt get created in the \userdata\zwave\ directory?
Edit: I also noticed in the database that itās showing User Codes and Entry Scheduling as channels but Iām not seeing those show up in HABmin. I only see Door Lock, General Alarm, and Battery channels?
Thanks.
Are both alarm_number and alarm_general required?
