@chris , few questions:
is PAD02 I entered yesterdey compiled into latest jar (from APR 16, 21h57m CET) ?
I’m asking as it’s still ‘Device Unknown’ after discovery, although zwave.log shows more information. This is BTW device ‘node5’ from the log below.
I’m seeing today messages ‘NODE 255: Transaction not completed: node address inconsistent. lastSent=255, incoming=255’ - it MAY be related to binding updated from Apr15 to Apr16, but not necessarily - any suggestions?
I’m seeing today a lot of ‘NODE 6: Polling aborted as no converter found for zwave:device:c9b27cea:node6:meter_current’ messages. They did not happened yesterday.
EDIT:
ad 3: This happens with a lot of nodes today, also for switch channels:
2017-04-17 10:52:35.633 [DEBUG] [ZWaveThingHandler ] - NODE 2: Command received zwave:device:c9b27cea:node2:switch_binary --> ON
2017-04-17 10:52:35.650 [DEBUG] [ZWaveThingHandler ] - NODE 2: No converter set for command zwave:device:c9b27cea:node2:switch_binary type OnOffType
Log exempt:
2017-04-17 10:33:37.271 [DEBUG] [zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=323, service.bundleid=191, service.scope=singleton} - org.openhab.binding.zwave
2017-04-17 10:33:37.293 [DEBUG] [ZWaveThingHandler ] - Initializing ZWave thing handler.
2017-04-17 10:33:37.323 [DEBUG] [ZWaveThingHandler ] - NODE 5: Controller status changed to ONLINE.
2017-04-17 10:33:37.331 [DEBUG] [ZWaveThingHandler ] - NODE 5: Controller is ONLINE. Starting device initialisation.
2017-04-17 10:33:37.342 [DEBUG] [ZWaveThingHandler ] - NODE 5: Updating node properties.
2017-04-17 10:33:37.344 [DEBUG] [ZWaveThingHandler ] - NODE 5: Updating node properties. MAN=316
2017-04-17 10:33:37.346 [DEBUG] [ZWaveThingHandler ] - NODE 5: Updating node properties. MAN=316. SET. Was 316
2017-04-17 10:33:37.349 [DEBUG] [ZWaveThingHandler ] - NODE 5: Properties synchronised
2017-04-17 10:33:37.360 [DEBUG] [ZWaveThingHandler ] - NODE 5: Configuration synchronised
2017-04-17 10:33:37.429 [DEBUG] [ZWaveThingHandler ] - NODE 5: Initialising Thing Node...
2017-04-17 10:33:37.430 [DEBUG] [ZWaveThingHandler ] - NODE 5: Polling intialised at 1800 seconds - start in 1800000 milliseconds.
2017-04-17 10:34:36.113 [DEBUG] [Handler$ZWaveReceiveThread] - Receive Message = 01 15 00 04 00 06 0F 32 02 21 44 00 00 00 04 01 2D 00 00 00 03 00 99
2017-04-17 10:34:36.133 [DEBUG] [ZWaveController ] - Receive queue TAKE: Length=0
2017-04-17 10:34:36.135 [DEBUG] [SerialMessage ] - Assembled message buffer = 01 15 00 04 00 06 0F 32 02 21 44 00 00 00 04 01 2D 00 00 00 03 00 99
2017-04-17 10:34:36.137 [DEBUG] [ZWaveController ] - Process Message = 01 15 00 04 00 06 0F 32 02 21 44 00 00 00 04 01 2D 00 00 00 03 00 99
2017-04-17 10:34:36.139 [DEBUG] [ZWaveController ] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 06 0F 32 02 21 44 00 00 00 04 01 2D 00 00 00 03 00
2017-04-17 10:34:36.142 [DEBUG] [icationCommandMessageClass] - NODE 6: Application Command Request (ALIVE:DONE)
2017-04-17 10:34:36.145 [DEBUG] [ZWaveNodeInitStageAdvancer] - NODE 6: Starting initialisation from DONE
2017-04-17 10:34:36.147 [DEBUG] [ZWaveController ] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1b270bb already registered
2017-04-17 10:34:36.150 [DEBUG] [icationCommandMessageClass] - NODE 6: Incoming command class METER
2017-04-17 10:34:36.152 [DEBUG] [ZWaveMeterCommandClass ] - NODE 6: Received METER command V3
2017-04-17 10:34:36.155 [DEBUG] [ZWaveMeterCommandClass ] - NODE 6: Meter: Type=Electric(1), Scale=kWh(0), Value=0.04
2017-04-17 10:34:36.157 [DEBUG] [ZWaveController ] - Notifying event listeners: ZWaveMeterValueEvent
2017-04-17 10:34:36.159 [DEBUG] [ZWaveThingHandler ] - NODE 6: Got an event from Z-Wave network: ZWaveMeterValueEvent
2017-04-17 10:34:36.161 [DEBUG] [ZWaveThingHandler ] - NODE 6: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 0.04
2017-04-17 10:34:36.164 [DEBUG] [icationCommandMessageClass] - NODE 255: Transaction not completed: node address inconsistent. lastSent=255, incoming=255
2017-04-17 10:34:37.092 [DEBUG] [Handler$ZWaveReceiveThread] - Receive Message = 01 15 00 04 00 06 0F 32 02 21 54 00 00 09 01 01 2D 00 00 09 15 00 9A
2017-04-17 10:34:37.120 [DEBUG] [ZWaveController ] - Receive queue TAKE: Length=0
2017-04-17 10:34:37.122 [DEBUG] [SerialMessage ] - Assembled message buffer = 01 15 00 04 00 06 0F 32 02 21 54 00 00 09 01 01 2D 00 00 09 15 00 9A
2017-04-17 10:34:37.125 [DEBUG] [ZWaveController ] - Process Message = 01 15 00 04 00 06 0F 32 02 21 54 00 00 09 01 01 2D 00 00 09 15 00 9A
2017-04-17 10:34:37.129 [DEBUG] [ZWaveController ] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 06 0F 32 02 21 54 00 00 09 01 01 2D 00 00 09 15 00
2017-04-17 10:34:37.131 [DEBUG] [icationCommandMessageClass] - NODE 6: Application Command Request (ALIVE:DONE)
2017-04-17 10:34:37.142 [DEBUG] [ZWaveNodeInitStageAdvancer] - NODE 6: Starting initialisation from DONE
2017-04-17 10:34:37.144 [DEBUG] [ZWaveController ] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1b270bb already registered
2017-04-17 10:34:37.147 [DEBUG] [icationCommandMessageClass] - NODE 6: Incoming command class METER
2017-04-17 10:34:37.151 [DEBUG] [ZWaveMeterCommandClass ] - NODE 6: Received METER command V3
2017-04-17 10:34:37.154 [DEBUG] [ZWaveMeterCommandClass ] - NODE 6: Meter: Type=Electric(1), Scale=W(2), Value=23.05
2017-04-17 10:34:37.157 [DEBUG] [ZWaveController ] - Notifying event listeners: ZWaveMeterValueEvent
2017-04-17 10:34:37.162 [DEBUG] [ZWaveThingHandler ] - NODE 6: Got an event from Z-Wave network: ZWaveMeterValueEvent
2017-04-17 10:34:37.164 [DEBUG] [ZWaveThingHandler ] - NODE 6: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 23.05
2017-04-17 10:34:37.166 [DEBUG] [icationCommandMessageClass] - NODE 255: Transaction not completed: node address inconsistent. lastSent=255, incoming=255
2017-04-17 10:34:38.106 [DEBUG] [Handler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 06 0B 32 02 A1 42 59 39 01 2D 59 8E 00 AF
2017-04-17 10:34:38.111 [DEBUG] [ZWaveController ] - Receive queue TAKE: Length=0
2017-04-17 10:34:38.116 [DEBUG] [SerialMessage ] - Assembled message buffer = 01 11 00 04 00 06 0B 32 02 A1 42 59 39 01 2D 59 8E 00 AF
2017-04-17 10:34:38.119 [DEBUG] [ZWaveController ] - Process Message = 01 11 00 04 00 06 0B 32 02 A1 42 59 39 01 2D 59 8E 00 AF
2017-04-17 10:34:38.123 [DEBUG] [ZWaveController ] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 06 0B 32 02 A1 42 59 39 01 2D 59 8E 00
2017-04-17 10:34:38.126 [DEBUG] [icationCommandMessageClass] - NODE 6: Application Command Request (ALIVE:DONE)
2017-04-17 10:34:38.128 [DEBUG] [ZWaveNodeInitStageAdvancer] - NODE 6: Starting initialisation from DONE
2017-04-17 10:34:38.130 [DEBUG] [ZWaveController ] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1b270bb already registered
2017-04-17 10:34:38.133 [DEBUG] [icationCommandMessageClass] - NODE 6: Incoming command class METER
2017-04-17 10:34:38.135 [DEBUG] [ZWaveMeterCommandClass ] - NODE 6: Received METER command V3
2017-04-17 10:34:38.138 [DEBUG] [ZWaveMeterCommandClass ] - NODE 6: Meter: Type=Electric(1), Scale=V(4), Value=228.41
2017-04-17 10:34:38.140 [DEBUG] [ZWaveController ] - Notifying event listeners: ZWaveMeterValueEvent
2017-04-17 10:34:38.142 [DEBUG] [ZWaveThingHandler ] - NODE 6: Got an event from Z-Wave network: ZWaveMeterValueEvent
2017-04-17 10:34:38.144 [DEBUG] [ZWaveThingHandler ] - NODE 6: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 228.41
2017-04-17 10:34:38.147 [DEBUG] [icationCommandMessageClass] - NODE 255: Transaction not completed: node address inconsistent. lastSent=255, incoming=255
2017-04-17 10:34:39.097 [DEBUG] [Handler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 06 0B 32 02 A1 4A 00 0B 01 2D 00 0B 00 10
2017-04-17 10:34:39.117 [DEBUG] [ZWaveController ] - Receive queue TAKE: Length=0
2017-04-17 10:34:39.119 [DEBUG] [SerialMessage ] - Assembled message buffer = 01 11 00 04 00 06 0B 32 02 A1 4A 00 0B 01 2D 00 0B 00 10
2017-04-17 10:34:39.122 [DEBUG] [ZWaveController ] - Process Message = 01 11 00 04 00 06 0B 32 02 A1 4A 00 0B 01 2D 00 0B 00 10
2017-04-17 10:34:39.125 [DEBUG] [ZWaveController ] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 06 0B 32 02 A1 4A 00 0B 01 2D 00 0B 00
2017-04-17 10:34:39.128 [DEBUG] [icationCommandMessageClass] - NODE 6: Application Command Request (ALIVE:DONE)
2017-04-17 10:34:39.130 [DEBUG] [ZWaveNodeInitStageAdvancer] - NODE 6: Starting initialisation from DONE
2017-04-17 10:34:39.132 [DEBUG] [ZWaveController ] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1b270bb already registered
2017-04-17 10:34:39.135 [DEBUG] [icationCommandMessageClass] - NODE 6: Incoming command class METER
2017-04-17 10:34:39.137 [DEBUG] [ZWaveMeterCommandClass ] - NODE 6: Received METER command V3
2017-04-17 10:34:39.139 [DEBUG] [ZWaveMeterCommandClass ] - NODE 6: Meter: Type=Electric(1), Scale=A(5), Value=0.11
2017-04-17 10:34:39.142 [DEBUG] [ZWaveController ] - Notifying event listeners: ZWaveMeterValueEvent
2017-04-17 10:34:39.144 [DEBUG] [ZWaveThingHandler ] - NODE 6: Got an event from Z-Wave network: ZWaveMeterValueEvent
2017-04-17 10:34:39.146 [DEBUG] [ZWaveThingHandler ] - NODE 6: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 0.11
2017-04-17 10:34:39.149 [DEBUG] [icationCommandMessageClass] - NODE 255: Transaction not completed: node address inconsistent. lastSent=255, incoming=255
2017-04-17 10:35:31.384 [DEBUG] [ZWaveThingHandler ] - NODE 6: Command received zwave:device:c9b27cea:node6:switch_binary --> REFRESH
2017-04-17 10:35:31.392 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling intialised at 1800 seconds - start in 50 milliseconds.
2017-04-17 10:35:31.397 [DEBUG] [ZWaveThingHandler ] - NODE 6: Command received zwave:device:c9b27cea:node6:switch_binary --> REFRESH
2017-04-17 10:35:31.400 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling intialised at 1800 seconds - start in 50 milliseconds.
2017-04-17 10:35:31.449 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling...
2017-04-17 10:35:31.450 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling zwave:device:c9b27cea:node2:switch_binary
2017-04-17 10:35:31.451 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling aborted as no converter found for zwave:device:c9b27cea:node2:switch_binary
2017-04-17 10:35:31.451 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling zwave:device:c9b27cea:node2:sensor_power
2017-04-17 10:35:31.452 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling aborted as no converter found for zwave:device:c9b27cea:node2:sensor_power
2017-04-17 10:35:31.452 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling zwave:device:c9b27cea:node2:meter_kwh
2017-04-17 10:35:31.453 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling aborted as no converter found for zwave:device:c9b27cea:node2:meter_kwh
2017-04-17 10:35:31.454 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling zwave:device:c9b27cea:node2:meter_watts
2017-04-17 10:35:31.454 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling aborted as no converter found for zwave:device:c9b27cea:node2:meter_watts
2017-04-17 10:35:31.455 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling zwave:device:c9b27cea:node2:meter_reset
2017-04-17 10:35:31.455 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling aborted as no converter found for zwave:device:c9b27cea:node2:meter_reset
2017-04-17 10:35:31.456 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling zwave:device:c9b27cea:node2:config_decimal_param61
2017-04-17 10:35:31.456 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling aborted as no converter found for zwave:device:c9b27cea:node2:config_decimal_param61
2017-04-17 10:35:31.457 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling zwave:device:c9b27cea:node2:config_decimal_param62
2017-04-17 10:35:31.457 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling aborted as no converter found for zwave:device:c9b27cea:node2:config_decimal_param62
2017-04-17 10:35:31.458 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling zwave:device:c9b27cea:node2:notification_send
2017-04-17 10:35:31.458 [DEBUG] [ZWaveThingHandler ] - NODE 2: Polling aborted as no converter found for zwave:device:c9b27cea:node2:notification_send
2017-04-17 10:35:31.459 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling...
2017-04-17 10:35:31.472 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling zwave:device:c9b27cea:node6:switch_binary
2017-04-17 10:35:31.474 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling aborted as no converter found for zwave:device:c9b27cea:node6:switch_binary
2017-04-17 10:35:31.481 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling zwave:device:c9b27cea:node6:meter_current
2017-04-17 10:35:31.483 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling aborted as no converter found for zwave:device:c9b27cea:node6:meter_current
2017-04-17 10:35:31.485 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling zwave:device:c9b27cea:node6:meter_kwh
2017-04-17 10:35:31.487 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling aborted as no converter found for zwave:device:c9b27cea:node6:meter_kwh
2017-04-17 10:35:31.491 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling zwave:device:c9b27cea:node6:meter_watts
2017-04-17 10:35:31.494 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling aborted as no converter found for zwave:device:c9b27cea:node6:meter_watts
2017-04-17 10:35:31.511 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling zwave:device:c9b27cea:node6:meter_voltage
2017-04-17 10:35:31.514 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling aborted as no converter found for zwave:device:c9b27cea:node6:meter_voltage
2017-04-17 10:35:31.516 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling zwave:device:c9b27cea:node6:alarm_power
2017-04-17 10:35:31.518 [DEBUG] [ZWaveThingHandler ] - NODE 6: Polling aborted as no converter found for zwave:device:c9b27cea:node6:alarm_power
