Honestly? A lot, maybe 10 tries before I got it to work as expected. To me the secure inclusion seems a little buggy.
@chris:
The latest version fo the dev branch is throwing tons of Java exceptions in karaf console. I am using version 2.1.0.201705152248 .
java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor66.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveComman
Class.handleApplicationCommandRequest(ZWaveCommandClass.java:245)
at org.openhab.binding.zwave.internal.protocol.ZWaveNode.processCommand
ZWaveNode.java:1284)
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$
WaveReceiveThread.run(ZWaveTransactionManager.java:413)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 6
Class.extractValue(ZWaveCommandClass.java:362)
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveConfig
rationCommandClass.handleConfigurationReport(ZWaveConfigurationCommandClass.jav
:97)
... 6 more
However, I cannot find any details for this in the logs (although I set debug level for Z-Wave binding).
Please provide somethign to support this (ie logs) - otherwise it canāt be fixed if there are problems.
The only issues that I have seen in logs are where devices havenāt been reset and therefore do not respond to the secure inclusion. A device can ONLY be securely included with 15 seconds of the completion of the network inclusion, so if a device has previously been included, it must be excluded first.
For me at least, Iāve not see any problems with the secure inclusion on devices Iāve include (my Yale lock - which Iāve include many many times) and a number of other device (switches, multi-sensorsā¦).
If you have logs showing problems, then please feel free to provide them though - itās the only way to fix them ;).
You need to correlate the time of the exception with the received message logs. This is an array out of bounds exception so it probably means that a message was received from a device which has an error. I really need to see this message to debug.
Where can I see the time of the exception? In Karaf console there is no timestamp with the exception message. So if I look from time to time in the console I only see that there was a new exception in the last hour or so. Is there any possibility to trace these exceptions with a timestamp?
Normally it should be logged in the logfile and it should then have a date/time logged.
No, unfortunately the exceptions are only displayed in Karaf console:
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveCommand
at org.openhab.binding.zwave.internal.protocol.ZWaveNode.processCommand(
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$Z
Caused by: java.lang.ArrayIndexOutOfBoundsException: 5
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveConfigu
rationCommandClass.handleConfigurationReport(ZWaveConfigurationCommandClass.java
:97)
... 7 more
:97)
... 7 more
:97)
... 7 more
:97)
... 7 more
:97)
... 7 more
:97)
... 7 more
:97)
... 7 more
:97)
... 7 more
:97)
... 7 more
:97)
... 7 more
:97)
... 7 more
:97)
... 7 more
:97)
... 7 more
:97)
... 7 more
at sun.reflect.GeneratedMethodAccessor114.invoke(Unknown Source)
:97)
... 6 more
There is no entry in the logs with the exception (only the usual stuff).
In this case I know it was between 15:41 and 16:10 this afternoon. I looked at more than 140.000 lines of debug log entries, but the only errors were some timoutsā¦no java exceptionā¦
Ok, then you need to try and correlate this another way - keep an eye out for the message that is incoming at the time of the exception. If itās happening often then it should be reasonably easy to see?
So far I do not understand when it happens or what the trigger is. There was no exception for more than 4 hours and then suddenly between 15:41 and 16:11 there come a couple of them.
My problem is that I do not know the time when it exactly happens. As I get nearly 100 lines of debug logs per second it is not useful to scan 30 minutes of debug logs. The only errors were timeouts and the only warnings some not initialized nodes.
I spent quite some time this evening to get it. When I restarted my system the exceptions occured soon after restart. I then stopped OH and took the log of the last 60 seconds before the exceptions.
Unfortunately the log is way too big to post it here (although it couvers only the last minute). Can I send you the file?
@chris Finally got some time to play around with OH2 and the refactored binding - the OH2 changes look really nice, much easier to include zwave devices, especially secure ones.
One issue I had with my kwikset 910. It took a couple of tried to get secure inclusion working (think it was too far away my first few attempts), then it worked and the lock appeared in the āplugā icon where I added it to the system.
Next day, I added anther (non-secure device), but the lock was back up in the plug icon again. I re-added it again, but now when I try to add a channel, the āNameā field is empty (instead of the usual zwave_device_15bfa0704b9_node#_description
text)
I have the logs but not my timestamps. Wondering if anyone has had this issue. Guessing I should just exclude and re include.
For what itās worth, my other devices are working well.
Dave
Chris, for the next build could you possibly comment out the node x is currently marked failed. My logs are almost nothing but those messages every 30s, even at INFO level and as far as I can tell they are unnecessary since all of those nodes still communicate and work as normal.
2017-05-17 06:23:31.236 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 49: Is currently marked as failed by the controller!
2017-05-17 06:23:31.260 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 31: Is currently marked as failed by the controller!
2017-05-17 06:23:31.265 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 50: Is currently marked as failed by the controller!
2017-05-17 06:24:01.241 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 49: Is currently marked as failed by the controller!
2017-05-17 06:24:01.264 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 31: Is currently marked as failed by the controller!
2017-05-17 06:24:01.270 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 50: Is currently marked as failed by the controller!
2017-05-17 06:24:31.245 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 49: Is currently marked as failed by the controller!
2017-05-17 06:24:31.268 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 31: Is currently marked as failed by the controller!
2017-05-17 06:24:31.275 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 50: Is currently marked as failed by the controller!
2017-05-17 06:24:32.366 [INFO ] [.smarthome.model.script.Illumination] - Motion Detected, turning on SwitchMasterBath_Dimmer
2017-05-17 06:24:41.072 [INFO ] [.smarthome.model.script.Illumination] - Motion Detected, turning on SwitchStairs_Dimmer
2017-05-17 06:24:41.074 [INFO ] [.smarthome.model.script.Illumination] - Motion Detected, turning on OutletStairs_Switch
2017-05-17 06:25:01.248 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 49: Is currently marked as failed by the controller!
2017-05-17 06:25:01.273 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 31: Is currently marked as failed by the controller!
2017-05-17 06:25:01.281 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 50: Is currently marked as failed by the controller!
You can always just type in the item name?
If HABmin doesnāt supply a default name, this almost certainly means that an item with the default name already exists. Since the item exists, HABmin doesnāt offer a default as it assumes that if youāre adding a second item to this channel, then you need to define the name yourself.
At some point I will reduce the logging, but at the moment I prefer to keep the logging as it is - this is a test binding after all, so I prefer to keep the āheavyā logging ;).
I will change this to debug though, but I assume most people running the test binding have debug enabled so that they can provide feedback and logs, so this wonāt impact anything.
I hope that makes sense.
Upgraded to:
231 | Active | 80 | 2.1.0.201705152248 | ZWave Binding
A few days ago and some sensors are now showing significant delays. One motion sensor now only registers several minutes after you leave the room and light switches and dimmers donāt seem to update status immediately in OH2 anymore.
Iāll try to get some logs this weekend
What did you upgrade from?
It was the 424 version of the .jar
Ok, there have been very few changes between these versions - itās mostly database updates. I think there was one small code change related to the multilevel switch converter.
Anyway, letās take a look at the logs and weāll seeā¦
So may be a dumb question, but excluding secure devices shouldnāt be any different than excluding non-secure devices, right? (i.e. if it consistently fails, I should open an issue, right?)
It should be the same. Iām not sure there will be much that I can do if itās failing - excluding a device is a case of sending a single command to the controllerā¦ Thereās one thing Iām thinking of doing is to stop all other traffic when inclusion/exclusion takes place - maybe this is related to your problem, so feel free to provide a log.If itās not that though, then thereās probably not much I can doā¦
