Wow, huge amount of devices! I can only tell for 18 devices: it’s working …
f.e. i have a popp rain sensor, which loose always his connection and dont update any data.
the neighbour list is not up to date, when i move the rain sensor near controller and wake it up than it updates, but when move back to destination, it updates one or two times.
there are also some other (powered) devices like fibaro switches or fibaro rgb which dont update.
all devices are spread over 3 buildings diameter is about 30m. and there are enough powered devices for mesh.
i have moved from fibaro hc2 to OH2 before some (6-10) weeks ago, on hc2 all devices was working.
so i think the problem why things loose connection or dont update is mesh heal (update neighbours does not work on current master)
I’m quite surprised about that and the information I have from most other people and discussions I’ve seen on the list is that the new binding works fine with the mesh updates. I’m not sure what else can be done to resolve that then.
Actually, looking at your image - are you REALLY sure you are running the development version? I see the question mark next to “security” - this shouldn’t happen with the development version - only the snapshot version. So, I think you are not running the development version - please confirm exactly what version you use.
no im on latest snapshot version (master)
i have not the development version, this is the reason, why im asking when you are planning to add the development version into master
Ok, my question above was if there was any reason not to merge this version (ie the development version) into the master, so when you said that the mesh update wasn’t working, I thought you meant it wasn’t working in the new version .
Anyway, I see you now removed this comment from your post above and now have another question. Since it is not related to this version I don’t think it’s relevant.
I would love to see the refactored Z-Wave binding into the 2.2.0 Snapshot releases !
Are you using the current development version? Is it working ok then?
Absolutely!
I am on it since the very begging of it.
I don’t have many devices (only 10, out of which only 1 is using security) and I have no problems at all.
Great - thanks
I’ve got 63 devices and everything seems to be working well with the 6/18 build. I guess the only real problem with wider distribution is that it will break everyone.
Having to delete and re add all zwave things is quite a task for people with >50 devices so it may be worth looking into a way to automate this as part of the install.
I agree, but snapshots are where the changes happen and that’s why I wanted to do it after the release - it gives us a few months to iron things out with an wider community…
I’m not really sure that’s possible - at least not within the binding. I’ll have a think about it though…
Thanks for the feedback.
I’d prefer to see this done before you add the new binding to the 2.2 snapshot. Other than that, I’m in.
Agreed - that was my point .
I have been using it for a while now with manually configured things! Only issue that I have is the DEAD items issue, I have 2 nodes that are marked DEAD by the controller but I still get updates from them.
You may want to look at manually configuring your .things, I found this a much better option for large networks.
I also have several devices being marked as failed but they communicate fine and I get all status updates. They come up and down randomly according to the logs.
good point
I have manually added all items but use things from discovery…
So going to the refactored version is maybe a good time to switch to .thing files …
deleting all zwave things and add them in the file should be fine?
can you post a few lines of zwave things to use for the syntax?
Bridge zwave:serial_zstick:controller "ZWave Controller" [ port="/dev/ttyACM0", controller_softreset="false", controller_master="true", controller_inclusiontimeout=60, heal_enable="true", heal_time=2, security_networkkey="AF 2D 9E 35 21 A1 ED 2B 45 B1 F4 DA 39 A8 B5 F2"
Thing zwave:rtc_ct100_00_000:controller:node2 "Node 2: CT100 - First Floor" (zwave:serial_zstick:controller) [ node_id=2 ] {
Channels:
Type sensor_temperature : sensor_temperature [ config_scale=1 ]
Type thermostat_setpoint : thermostat_setpoint_cooling [ config_scale=1 ]
Type thermostat_setpoint : thermostat_setpoint_heating [ config_scale=1 ]
Thing zwave:homeseer_hswd100_00_000:controller:node22 "Node 22: HSWD100 - Outside Front Door Lights" (zwave:serial_zstick:controller) [ node_id=22 ]
Thing zwave:enerwave_zw20r_00_000:controller:node30 "Node 30: ZW20R - House Outside Outlet A" (zwave:serial_zstick:controller) [ node_id=30 ]
Thing zwave:ge_zw4002_00_000:controller:node44 "Node 44: ZW4002 - Master bedroom Fan" (zwave:serial_zstick:controller) [ node_id=44 ]
Thing zwave:yale_yrl220_00_000:controller:node50 "Node 50: YRL220 - Front Door" (zwave:serial_zstick:controller) [ node_id=50 ]
That’s about the same behaviour as I see here. Handling of dead/failed nodes isn’t perfect. But then again in my experience that’s the big are of problem with z-wave in general, with all softwares I’ve used, so I can’t say this one is worse than anything else. Except for this everything is working like a charm for me, so I would say it’s ready for wider testing.
I am using it for 3 Months now, 2 parallel controllers (2 Home Ids), 100 devices, 350 items. Currently I am running the 20150625 version.
Overall impression is really good, but there are a couple of points that need to be fixed:
- Setting of Multiinstance associations for Zwave+ devices with multiple endpoints (important)
- Dead node problem (important, but aleady mentioned by many other people here)
- No unqiue reference to nodes in logs when used with mutiple controllers as only node id is shown (nice to have)
Thank a lot for your great work! The multi controller option is absolutely fantastic allowing me to operate separate networks by floor. This solved all problems of my big concrete floors and reduced timeouts to close to zero. And it even allows you to operate even more than 230 Zwave nodes in a house (in theory, my network is not that big yet)
Cheers!
Martin
