Hi All and @chris,
I’m recently setup an instance of OH2 and hoping to migrate my setup to it soon. Also recently purchased a Zooz ZSE40 that I am putting it in the OH2 instance.
I see that ZSE40 has been added to the database, thank you @chris for that!
I setup the ZWAVE binding, thing and channel for the ZSE40 in paper UI and I manually enter the items in /etc/openhab2/items (I like it better than the paper UI items).
Here are the items.
Contact ZoozBinary "Zooz Binary" { channel="zwave:device:89326432:node4:sensor_binary" }
Contact ZoozMotion "Zooz Motion" { channel="zwave:device:89326432:node4:alarm_motion" }
Contact ZoozTamper "Zooz Tamper" { channel="zwave:device:89326432:node4:alarm_tamper" }
Number ZoozHumidity "Zooz Humidity" <humidity> { channel="zwave:device:89326432:node4:sensor_relhumidity" }
Number ZoozLight "Zooz Light" { channel="zwave:device:89326432:node4:sensor_luminance" }
Number ZoozTemperature "Zooz Temperature" <temperature> { channel="zwave:device:89326432:node4:sensor_temperature" }
Number ZoozBattery "Zooz Battery" <battery> { channel="zwave:device:89326432:node4:battery_level" }
First of all, in the Paper UI, the channel for battery is “zwave:device:89326432:node4:battery-level”. If I put this in, it doesn’t give me any results. So, i changed it to “zwave:device:89326432:node4:battery_level”, which seems to work. Not sure if this is a bug, or I did something wrong.
Second, ZoozTamper (zwave:device:89326432:node4:alarm_tamper) and ZoozBinary (zwave:device:89326432:node4:sensor_binary) don’t seem to do anything at all. Not sure if other people have any lucks with this one.
Finally, ZoozMotion (zwave:device:89326432:node4:alarm_motion) seems to be generating an error in the error log whenever the ZSE40 sends a motion detected singal over.
2017-07-31 01:51:26.058 [ERROR] [ve.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
java.lang.IllegalArgumentException: No enum constant org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass.AlarmType.MOTION
at java.lang.Enum.valueOf(Enum.java:238)[:1.8.0_131]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$AlarmType.valueOf(ZWaveAlarmCommandClass.java:1)[208:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.converter.ZWaveAlarmConverter.handleNotificationReport(ZWaveAlarmConverter.java:144)[208:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.converter.ZWaveAlarmConverter.handleEvent(ZWaveAlarmConverter.java:109)[208:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.ZWaveIncomingEvent(ZWaveThingHandler.java:1099)[208:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.notifyEventListeners(ZWaveController.java:567)[208:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass.processNotificationReport(ZWaveAlarmCommandClass.java:194)[208:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass.handleApplicationCommandRequest(ZWaveAlarmCommandClass.java:124)[208:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:119)[208:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:248)[208:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:214)[208:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$7(ZWaveController.java:208)[208:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1324)[208:org.openhab.binding.zwave:2.1.0]
Everything else seems to be working.
I am on OH2 2.1 and zwave:2.1.0 (from the error log). The binding was installed from Paper UI.
Anyone else has similiar issue? Any luck on resolving it?
Thanks,
Joe
