604435
(Marcin)
February 15, 2017, 6:52pm
#1
My zwave devices works correctly but I’ve errors in my log file:
2017-02-15 17:50:47.536 [ERROR] [ssage.ApplicationCommandMessageClass] - Error processing frame: Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 20 08 59 06 01 06 20 01 26 01 >> Attempt to read message payload out of bounds: Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 20 08 59 06 01 06 20 01 26 01 (11)
My configuration:
OH2 Snapshot 14.02.2016
Manufacturer: Goap/Qubino
Manufacturer ID: 0159
Device Description: Flush Shutter
+2x qubino flush relays+3x azr Rollershutter
Any idea what can cause this error?
Trace log: https://dl.dropboxusercontent.com/u/14910347/openhab.zip
Node.xml from OH1: https://dl.dropboxusercontent.com/u/14910347/node14.xml
604435
(Marcin)
February 16, 2017, 5:44pm
#2
And something that + attached Node14.xml from OH2 https://www.dropbox.com/s/1wgg76kqdz2cari/node14_OH2.xml?dl=0
2017-02-16 18:12:39.730 [WARN ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Unsupported multi instance command version: 0.
@chris Hi, Chris. Same here… Any idea?
15:59:52.392 [WARN ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Unsupported multi instance command version: 0.
15:59:52.394 [WARN ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Unsupported multi instance command version: 0.
15:59:52.396 [WARN ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Unsupported multi instance command version: 0.
15:59:52.399 [WARN ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Unsupported multi instance command version: 0.
qubino 1D relay
chris
(Chris Jackson)
July 11, 2017, 11:06am
#4
I’d suggest to reinitialse the device as this is probably caused by a problem during initialisation.
Openhab 2.1 release. No way. Same thing:
16:25:05.328 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Command received zwave:device:15bbe728e21:node6:switch_binary --> REFRESH
16:25:05.329 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling intialised at 1800 seconds - start in 50 milliseconds.
16:25:05.379 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling…
16:25:05.380 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:15bbe728e21:node6:switch_binary
16:25:05.381 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 6: Generating poll message for SWITCH_BINARY, endpoint 0
16:25:05.388 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 6: Creating new message for application command SWITCH_BINARY_GET
16:25:05.390 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:15bbe728e21:node6:sensor_binary
16:25:05.391 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:15bbe728e21:node6:sensor_temperature
16:25:05.392 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:15bbe728e21:node6:switch_binary1
16:25:05.393 [WARN ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Unsupported multi instance command version: 0.
16:25:05.395 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:15bbe728e21:node6:sensor_binary2
16:25:05.458 [WARN ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Unsupported multi instance command version: 0.
16:25:05.459 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:15bbe728e21:node6:sensor_temperature2
16:25:05.476 [WARN ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Unsupported multi instance command version: 0.
16:25:05.478 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:15bbe728e21:node6:alarm_burglar2
16:25:05.479 [WARN ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Unsupported multi instance command version: 0.
16:25:05.855 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 6: Sending REQUEST Message = 01 09 00 13 06 02 25 02 25 25 C6
16:25:05.918 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: Sent Data successfully placed on stack.
16:25:06.029 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: SendData Request. CallBack ID = 37, Status = Transmission complete and ACK received(0)
16:25:06.030 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Starting initialisation from DONE
16:25:06.122 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 6: Application Command Request (ALIVE:DONE)
16:25:06.123 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Starting initialisation from DONE
16:25:06.126 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 6: Incoming command class SWITCH_BINARY
16:25:06.128 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 6: Switch Binary report, value = 0
16:25:06.136 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 6: Response processed after 253ms/891ms.
chris
(Chris Jackson)
July 11, 2017, 11:28am
#6
This is following a reinitialisation? Please provide the full debug log following the reinitialisation and I’ll take a look.
Here is reinitialisation debug
https://pastebin.com/5NZaGCFr
chris
(Chris Jackson)
July 11, 2017, 11:39am
#8
So, to clarify what you’ve done - did you click on the “Reinitialise device” option in HABmin or have you done something else? I don’t really see anything linked to the initialisation of the device in the log.
Sorry. Found right button. =)
https://pastebin.com/2u9ST5GR
chris
(Chris Jackson)
July 11, 2017, 11:51am
#10
Is the problem gone now? I don’t see any errors in the log?
brutevinch
(brutevinch)
July 11, 2017, 11:53am
#11
I’ll Wait some time and let you know.
(BTW if you can please help me with fgd-211. FGD-211 command=configuration )
