Hi, I face an issue with the inclusion of DCH-Z110 z-wave device into OH2. I used the OH1 before and have another device of same type already running without any issue.
Now after moving to OH2 I tried to include an additional DCH-Z110 via Paper-UI and Habmin. In both cases the sensor is found as a thing with node address. After some time the device information turns from unknown to DCH-Z110 in the interface, that’s normal for a battery powered device. But the device status reads: UNINITIALIZED - HANDLER_MISSING_ERROR.
I am not able to change device configuration (change notification type to SENSOR_BINARY REPORT) results in ERROR 500 - Internal Server Error. Also if I connect the channel they will never update.
Am I missing something here? What can I do to locate the problem?
BR
Carsten
