I have a Fibaro dual relay switch. The status from one channel is not updated when operating manually.
Expect it’s due to the the fact the the channel uses switch_binary1 and switch_binary2 and updates are received for switch_binary and switch_binary2
Is this an OH bug are a ZWave issue and is there any way to work around this ?
I might have a similar issue with a Fibaro dual dimmer, but did not check the logs yet.
Below a part of the log which shows this. (Thing is configured via the OH3 GUI)
Initializing ZWave thing handler zwave:device:controller:node14.
NODE 14: Initialising cmd channel zwave:device:controller:node14:switch_binary for OnOffType
NODE 14: Initialising state channel zwave:device:controller:node14:switch_binary for OnOffType
NODE 14: Initialising cmd channel zwave:device:controller:node14:switch_binary1 for OnOffType
NODE 14: Initialising state channel zwave:device:controller:node14:switch_binary1 for OnOffType
NODE 14: Initialising cmd channel zwave:device:controller:node14:switch_binary2 for OnOffType
NODE 14: Initialising state channel zwave:device:controller:node14:switch_binary2 for OnOffType
NODE 14: Updating channel state zwave:device:controller:node14:switch_binary to ON [OnOffType]
NODE 14: Updating channel state zwave:device:controller:node14:switch_binary2 to ON [OnOffType]
NODE 14: Updating channel state zwave:device:controller:node14:switch_binary2 to OFF [OnOffType]
NODE 14: Updating channel state zwave:device:controller:node14:switch_binary to OFF [OnOffType]
NODE 14: Command received zwave:device:controller:node14:switch_binary1 --> ON [OnOffType]
NODE 14: Command received zwave:device:controller:node14:switch_binary1 --> OFF [OnOffType]
NODE 14: Polling zwave:device:controller:node14:switch_binary1
NODE 14: Polling skipped for zwave:device:controller:node14:switch_binary1 on COMMAND_CLASS_BASIC
NODE 14: Polling zwave:device:controller:node14:switch_binary2
NODE 14: Polling skipped for zwave:device:controller:node14:switch_binary2 on COMMAND_CLASS_BASIC
NODE 14: Updating channel state zwave:device:controller:node14:switch_binary1 to OFF [OnOffType]
NODE 14: Command received zwave:device:controller:node14:switch_binary2 --> ON [OnOffType]
NODE 14: Command received zwave:device:controller:node14:switch_binary2 --> OFF [OnOffType]
