Tried to migrate an old DSL rule to JavaScript, but I always get the following error message:
Script execution of rule with UID ‘pyduofern_az_spielplatz’ failed: ReferenceError: “executeCommandLine” is not defined in at line number 14
Here’s the script:
var logger = Java.type("org.slf4j.LoggerFactory").getLogger("org.openhab.rule." + ctx.ruleUID); var received_command = itemRegistry.getItem('pyduofern_az_spielplatz').getState(); var ScriptResponse = "" logger.info("Rule wurde getriggert. Empfangener Befehl: " + received_command); switch (received_command) { case ON: ScriptResponse = executeCommandLine(Duration.ofSeconds(60), "python3","/etc/openhab/_duofern/duofern_cli.py", "--up", "495dbd", "--configfile", "/etc/openhab/_duofern/.duofern.json"); logger.info("RC=" + ScriptResponse); break; case OFF: ScriptResponse = executeCommandLine(Duration.ofSeconds(60), "python3", "/etc/openhab/_duofern/duofern_cli.py", "--down", "495dbd", "--configfile", "/etc/openhab/_duofern/.duofern.json"); logger.info("RC=" + ScriptResponse); break; default: logger.info("Unbekannter Befehl - keine Aktion gestartet"); }
Where’s my error? Thanks!
