Hi there,
i moved this rule to oH3.1 some time ago but never tested it and it wasn´t fired by an empty battery.
Now it´s running but fails to send me the message because of a conversion error.
val String ruleId = "BatteryCheck"
rule "Batterien prüfen"
Time cron "0 0 18 * * ?"
val telegramAction = getActions("telegram","telegram:telegramBot:bot")
val long bot1 = 456
val long bot2 = 123
val StringBuilder BatterieText = new StringBuilder
BatterieText.append("Folgende Batterien sind leer:\n")
var Integer emptyBatteriesS = 0
var Integer emptyBatteriesP = 0
emptyBatteriesS = gBatteryState.members.filter[ i | i.state == ON].size
emptyBatteriesP = gBatteryPercent.members.filter[ i | i.state <= 20].size
val emptyBatteries = emptyBatteriesS + emptyBatteriesP
if(emptyBatteries == 1)
logInfo(ruleId, "Eine Batterie ist leer.", emptyBatteries)
if(emptyBatteries > 1)
logInfo(ruleId, "{} Batterien sind leer.", emptyBatteries)
if(emptyBatteries != 0)
gBatteryState.members.filter[ i | i.state == ON].forEach[ i | BatterieText.append(i.state+" - ")]
gBatteryState.members.filter[ i | i.state == ON].forEach[ i | BatterieText.append(i.label+"\n")]
gBatteryPercent.members.filter[ i | i.state <= 20].forEach[ i | BatterieText.append(i.label+" - ")]
gBatteryPercent.members.filter[ i | i.state <= 20].forEach[ i | BatterieText.append(i.state+"%\n")]
Thread::sleep(100)
logInfo(ruleId, BatterieText.toString)
telegramAction.sendTelegram(bot1, BatterieText.toString)
telegramAction.sendTelegram(bot2, BatterieText.toString)
The rule is working until it should send the telegram message.
The line before will be executed: logInfo(ruleId, BatterieText.toString)
2021-09-06 19:37:13.512 [INFO ] [enhab.core.model.script.BatteryCheck] - Eine Batterie ist leer.
2021-09-06 19:37:13.653 [INFO ] [enhab.core.model.script.BatteryCheck] - Folgende Batterien sind leer:
Sensor Flur - 18%
2021-09-06 19:37:13.659 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'batteryCheck-1' failed: Conversion = '
' in batteryCheck
I can´t find a place where the '
is coming from.
It´s not in the name or the state of any group member.
Any ideas?
- Platform information:
- Hardware: Raspberry Pi 4 Model B Rev 1.1
- OS: Raspbian GNU/Linux 10 (buster)
- Java Runtime Environment:
- openjdk version “11.0.12” 2021-07-20 LTS
- OpenJDK Runtime Environment Zulu11.50+19-CA (build 11.0.12+7-LTS)
- OpenJDK Client VM Zulu11.50+19-CA (build 11.0.12+7-LTS, mixed mode)
- openHAB version: 3.1.0 (Build)
