Issue:
An Item value is not displayed on a sitemap widget, no matter what widget I use. This Item value is calculated with Jython script based on values from another Item.
Calculating PVPower as a sum from two PV Strings. This PVPower value is visible in the Item as well on PaperUI and HABPanel widgets.
On Sitemap this value is not displayed.
Any Idea why Sitemap widgets behave different? I tried with several value Types: String, Number, Number:Power but no difference…
Your Item has metadata. A section of that metadata controls how the Item state is presented in the UI. The state presentation section. The key property there is called pattern.
First of all, read the installation prerequisits and install the correct Java version.
openHAB 3 requires Java 11 (Zulu 11 recommended), no higher, no lower version.
I just found out its OpenJDK11… For some reason I was under the impression its 14 but its not.
Nevertheless, its solved already. Thanks for the sidenote
