- Platform information:
- Hardware: Raspberry 3B+ LAN connected with Openhabian on 32GB SD card
Fresh Install, in openhabian.conf: hostname, password, debug maximum changed
Issue1:
Mosquitto not available after Install:
Search forum and applied
sudo mkdir -p /var/log/mosquitto /opt/zram/log.bind/mosquitto sudo chown mosquitto /var/log/mosquitto /opt/zram/log.bind/mosquitto sudo systemctl start mosquitto.service
Create /lib/systemd/system/mosquitto.service.d/override.conf
to contain
[Unit] After=network-online.target zram-config.service Wants=network-online.target zram-config.service
Mosquitto works after reboot
Issue 2:
Grafana not available after Install
Search forum and applied:
sudo mkdir -p /var/log/grafana /opt/zram/log.bind/grafana
sudo chown grafana /var/log/grafana /opt/zram/log.bind/grafana
Grafana Works after reboot
Issue 3:
Menue Item “Fix Permissions” returned with Errors.
From Log output it seems ‘/var/log/openhab’ missing
Search Web and applied:
‘sudo mkdir /var/log/openhab’
‘sudo chown openhab: /var/log/openhab’
after reboot fix permissions works, frontail gives more output
Questions:
- What did I do wrong in installing?
- How can I be sure, that system is correctly setup, especially zram setup, and additional functions like logging, backup, etc.?
Thank you for help
