I need help getting a Homeseer HS-LS100+ working. I used Main UI to include the sensor into the zwave network, added the thing and added items for the flood-alarm and battery level channels. Everything seems normal and MainUi shows the thing as Online, but the items are never updated - after three days they are still null.
I’ve tried excluding/including the items multiple times including deleting the nodes from the controller (Aeotec Z-Stick gen5), but the result is always the same – the items are never updated.
The one oddity that I found is that there is no file for the node in the userdata/zwave folder. I added a couple of dimmers a week ago and the files exist for those nodes.
The thing’s configuration is:
UID: zwave:device:39d51d11b2:node32
label: Master Bath Left Leak Sensor
thingTypeUID: zwave:homeseer_hsls100_00_000
configuration:
config_20_2: 1040
config_32_1: 20
wakeup_interval: 0
group_1:
- controller
group_2:
- controller
wakeup_node: 1
config_17_1: 5
config_18_1: 0
config_19_1: 0
config_22_2: 320
config_24_1: 1
config_14_1: 1
node_id: 32
config_15_1: 0
bridgeUID: zwave:serial_zstick:39d51d11b2
The channels are:
zwave:device:39d51d11b2:node32:alarm_flood
zwave:device:39d51d11b2:node32:battery-level
And the items are:
Can anyone help with this? I’ve exhausted everything I can think of to try to get these working.
Openhab 3.1.0 Relase Build running in Docker on a Synology NAS.
