ich have a problem regarding OH3.3.0 and KNX Binding. Since the latest upgrade the connection to the knx gateway has become unstable, following output shows in openhab.log frequently.
2022-08-01 07:32:41.366 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:bridge’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): server request
[ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:bridge’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): no heartbeat response
I have the same problem since yesterday. I had to restart my windows server with the openHAB virtual machine running on centOS.
But the update only affected the server. an older version of openHAB 3.1 (Friday) also no longer gets a KNX connection.
Sometimes I get the message “could not accept new connection (maximum reached)”.
All my searches and attempts were unsuccessful.
“maximum reached” is a different problem. Usually the KNX Gateways have maximum number of sessions, so when they´re all block by openhab, ETS etc. or may not be properly closed, the sessions are stuck on the knx ip gw. In that case on my side helps to “shut / no shut” the switchport where the knx ip gw is connected.
I know that’s a different problem, but I much more often have your messages and:
“The KNX network link was detached from the process communicator” and
“KNX link has been lost (reason: server request on object tunneling link (closed) 192.168.10.112:3671 TP1 medium, device 0.0.0, hopcount 6)” and
“Establishing connection to KNX bus on 192.168.10.112:3671 in mode TUNNEL.”
Do you mean closing and opening the switch port is different than pulling the LAN plug and de-energizing the gateway.
Do you speak german?
2022-08-09 11:52:03.190 [WARN ] [net/IP Tunneling 192.168.178.10:3671] - **received disconnect response status 0x21 (no active data connection with that ID**)
2022-08-09 11:52:03.199 [ERROR] [net/IP Tunneling 192.168.178.10:3671] - **close connection - maximum send attempts**
tuwien.auto.calimero.KNXAckTimeoutException: maximum send attempts, no service acknowledgment received
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:253) ~[?:?]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send(KNXnetIPTunnel.java:213) ~[?:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.onSend(KNXNetworkLinkIP.java:423) ~[?:?]
at tuwien.auto.calimero.link.AbstractLink.send(AbstractLink.java:385) ~[?:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendRequestWait(KNXNetworkLinkIP.java:402) ~[?:?]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.sendData(TransportLayerImpl.java:351) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.send(ManagementClientImpl.java:1275) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.send(ManagementClientImpl.java:1259) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.sendWait2(ManagementClientImpl.java:1295) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.readDeviceDesc(ManagementClientImpl.java:595) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementProceduresImpl.isAddressOccupied(ManagementProceduresImpl.java:391) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.isReachable(AbstractKNXClient.java:355) ~[?:?]
at org.openhab.binding.knx.internal.handler.AbstractKNXThingHandler.pollDeviceStatus(AbstractKNXThingHandler.java:147) ~[?:?]
at org.openhab.binding.knx.internal.handler.AbstractKNXThingHandler.lambda$1(AbstractKNXThingHandler.java:187) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
