I’m sorry, Rich is one of the most active and as it happens the most liked user here in the forum. I’m afraid you are the arrogant one.
Please calm down a bit and take a step back and read again through this thread. You gave (and give) not the impression to have
read the sources we gave you
told us what you already tried - and failed to do
told us, what obstacles you face
but: you have told us
to solve your problem nevertheless
even doubled down on your position - after being told so from multiple users here on the forum
Thank you, I have already found this version and saved it in the “Addons” folder. A recommended rule is installed to trigger the query. But it doesn’t work. (The Exec binding is also installed.)
I actually always take a lot of time when problems arise - that was also the case this time. Since I can’t get any further, I will forego the new binding and speed test.
writing the json output to /opt/openhab/userdata/tmp/ookla.json, this file is then
parsed by the speedtest rule (instead of executing the ookla speedtest and fetching the json like in the original rule). To do so, i added a try-catch block around, reading the file and convert the pretty json to a one-liner with 2 regex. (-> see MODIFICATION START / END)
cronjob is running the ookla speedtest container every minute.
speedtest.rules:
// MODIFICATION START
import java.nio.file.Files
import java.nio.file.Paths
// MODIFICATION END
val String ruleId = "Speedtest"
val Number calc = 125000 // Converting from bits to Mbits
rule "Speedtest init"
System started
createTimer(now.plusSeconds(195))
if(SpeedtestRerun.state == NULL)
SpeedtestRerun.postUpdate(OFF)
if(SpeedtestRunning.state == NULL)
SpeedtestRunning.postUpdate("-")
if(SpeedtestSummary.state == NULL || SpeedtestSummary.state == "")
SpeedtestSummary.postUpdate("⁉ (unbekannt)")
rule "Speedtest"
Time cron "0 0/15 * * * ?" or
Item SpeedtestRerun changed from OFF to ON or
Item SpeedtestRerun received command ON
//logInfo(ruleId, "--> speedtest executed...")
SpeedtestRunning.postUpdate("Messung läuft...")
// execute the script, you may have to change the path depending on your system
// Please use -f json and not -f json-pretty
//val speedtestExecute = "speedtest --accept-gdpr --accept-license -f json"
var String speedtestCliOutput;
try {
speedtestCliOutput = new String(Files.readAllBytes(Paths.get("/openhab/userdata/tmp/ookla.json")))
speedtestCliOutput = speedtestCliOutput.replaceAll("\\s+", "").replaceAll("\\r\\n+","")
// MODIFICATION END
// for debugging:
// var String speedtestCliOutput = "Ping: 43.32 ms\nDownload: 21.64 Mbit/s\nUpload: 4.27 Mbit/s"
logInfo(ruleId, "--> speedtest output after readfile:\n" + speedtestCliOutput + "\n\n")
SpeedtestRunning.postUpdate("Datenauswertung...")
// starts off with a fairly simple error check, should be enough to catch all problems I can think of
if (speedtestCliOutput.startsWith("{\"type\":\"result\",") && speedtestCliOutput.endsWith("}}"))
var ping = Float::parseFloat(transform("JSONPATH", "$.ping.latency", speedtestCliOutput))
SpeedtestResultPing.postUpdate(ping)
var float down = Float::parseFloat(transform("JSONPATH", "$.download.bandwidth", speedtestCliOutput))
down = (down / calc)
SpeedtestResultDown.postUpdate(down)
var float up = Float::parseFloat(transform("JSONPATH", "$.upload.bandwidth", speedtestCliOutput))
up = (up / calc)
SpeedtestResultUp.postUpdate(up)
var String url = transform("JSONPATH", "$.result.url", speedtestCliOutput)
val img = url + ".png"
SpeedtestResultImage.postUpdate(img)
SpeedtestSummary.postUpdate(String::format("ᐁ %.1f Mbit/s ᐃ %.1f Mbit/s (%.0f ms)", down, up, ping))
// update timestamp for last execution
val DateTimeType ResultDate = DateTimeType.valueOf(transform("JSONPATH", "$.timestamp", speedtestCliOutput))
SpeedtestResultDate.postUpdate(ResultDate)
else
SpeedtestResultPing.postUpdate(0)
SpeedtestResultDown.postUpdate(0)
SpeedtestResultUp.postUpdate(0)
SpeedtestSummary.postUpdate("(unbekannt)")
SpeedtestRunning.postUpdate("Fehler")
logError(ruleId, "--> speedtest failed. Output:\n" + speedtestCliOutput + "\n\n")
} catch (IOException e){
SpeedtestRunning.postUpdate("File Error")
logError(ruleId, "--> speedtest failed. Output:\nookla output reading failed!\n\n")
// MODIFICATION END
