I’m running OH3.4 and InfluxDB2 (v2.5.1) under Windows 11. I’m having unauthorized access problem so my data is not persisted to influxdb.
I get following messages in OH log:
2023-01-06 08:08:02.396 [ERROR] [.client.write.events.WriteErrorEvent] - The error occurred during writing of data
com.influxdb.exceptions.UnauthorizedException: unauthorized access
at com.influxdb.internal.AbstractRestClient.responseToError(AbstractRestClient.java:98) ~[bundleFile:?]
at com.influxdb.client.internal.AbstractWriteClient.toInfluxException(AbstractWriteClient.java:574) ~[bundleFile:?]
at com.influxdb.client.internal.AbstractWriteClient.lambda$new$12(AbstractWriteClient.java:181) ~[bundleFile:?]
at io.reactivex.internal.subscribers.LambdaSubscriber.onNext(LambdaSubscriber.java:65) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableDoFinally$DoFinallySubscriber.onNext(FlowableDoFinally.java:84) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapMaybe$ConcatMapMaybeSubscriber.drain(FlowableConcatMapMaybe.java:284) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapMaybe$ConcatMapMaybeSubscriber.onNext(FlowableConcatMapMaybe.java:137) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapSingle$ConcatMapSingleSubscriber.drain(FlowableConcatMapSingle.java:279) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapSingle$ConcatMapSingleSubscriber.innerSuccess(FlowableConcatMapSingle.java:179) [bundleFile:?]
at io.reactivex.internal.operators.mixed.FlowableConcatMapSingle$ConcatMapSingleSubscriber$ConcatMapSingleObserver.onSuccess(FlowableConcatMapSingle.java:317) [bundleFile:?]
at io.reactivex.internal.operators.single.SingleMap$MapSingleObserver.onSuccess(SingleMap.java:64) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableCollectSingle$CollectSubscriber.onComplete(FlowableCollectSingle.java:119) [bundleFile:?]
at io.reactivex.internal.subscribers.BasicFuseableSubscriber.onComplete(BasicFuseableSubscriber.java:120) [bundleFile:?]
at io.reactivex.internal.subscribers.BasicFuseableConditionalSubscriber.onComplete(BasicFuseableConditionalSubscriber.java:119) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$State.checkTerminated(FlowableGroupBy.java:686) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$State.drainNormal(FlowableGroupBy.java:626) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$State.drain(FlowableGroupBy.java:558) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$State.onComplete(FlowableGroupBy.java:548) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$GroupedUnicast.onComplete(FlowableGroupBy.java:474) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableGroupBy$GroupBySubscriber.onComplete(FlowableGroupBy.java:213) [bundleFile:?]
at io.reactivex.processors.UnicastProcessor.checkTerminated(UnicastProcessor.java:430) [bundleFile:?]
at io.reactivex.processors.UnicastProcessor.drainRegular(UnicastProcessor.java:314) [bundleFile:?]
at io.reactivex.processors.UnicastProcessor.drain(UnicastProcessor.java:397) [bundleFile:?]
at io.reactivex.processors.UnicastProcessor.onComplete(UnicastProcessor.java:487) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowBoundarySupplier$WindowBoundaryMainSubscriber.drain(FlowableWindowBoundarySupplier.java:254) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowBoundarySupplier$WindowBoundaryMainSubscriber.innerNext(FlowableWindowBoundarySupplier.java:166) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowBoundarySupplier$WindowBoundaryInnerSubscriber.onNext(FlowableWindowBoundarySupplier.java:316) [bundleFile:?]
at io.reactivex.processors.PublishProcessor$PublishSubscription.onNext(PublishProcessor.java:360) [bundleFile:?]
at io.reactivex.processors.PublishProcessor.onNext(PublishProcessor.java:243) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableFlatMap$MergeSubscriber.tryEmit(FlowableFlatMap.java:282) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableFlatMap$InnerSubscriber.onNext(FlowableFlatMap.java:668) [bundleFile:?]
at io.reactivex.subscribers.SerializedSubscriber.onNext(SerializedSubscriber.java:100) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowTimed$WindowExactBoundedSubscriber.drainLoop(FlowableWindowTimed.java:498) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableWindowTimed$WindowExactBoundedSubscriber$ConsumerIndexHolder.run(FlowableWindowTimed.java:579) [bundleFile:?]
at io.reactivex.Scheduler$Worker$PeriodicTask.run(Scheduler.java:479) [bundleFile:?]
at io.reactivex.internal.schedulers.ScheduledRunnable.run(ScheduledRunnable.java:66) [bundleFile:?]
at io.reactivex.internal.schedulers.ScheduledRunnable.call(ScheduledRunnable.java:57) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
INfluxDB persistence service window is shown below:
I have looked at the community and there have been rather similar issues, e.g. in this post.
InfluxDB window shows also errors (see below):
My influxdb persist file is:
// persistence strategies have a name and definition and are referred to in the "Items" section
Strategies {
everymin : "0 * * * * ?"
* Each line in this section defines for which Item(s) which strategy(ies) should be applied.
* You can list single items, use "*" for all items or "groupitem*" for all members of a group
* Item (excl. the group Item itself).
Items {
ABB_A43_imp_energy : strategy = everymin
Adam6250_Fortum_emittari : strategy = everymin
Adam6250_vesimittari : strategy = everymin
I have checked that the token which I created in Influxdb web interface is active and it is All Access API Token.
I have tried to use username/password authorization without the token and also without username/password but with the token but I still get the same errors in the OH log.
I can import my historic data into the bucket using annotated csv format so the database should be fine and I can look at the data in the web interface.
Any ideas?
